Hi All,
I'm missing one wheel lug from one rim. Does anybody know what kind of lug it is and also where I can source one? As can be seen in the photo, there are two rectangular slots for the lug to fit in. Thanks.
John
missing wheel lug, what kind, where source
- Last Name: Humble
Re: missing wheel lug, what kind, where source
Just did that myself yesterday. There are no new lugs availabe as far as I know. Spare lugs come from junk rims, they are easy to remove and brase in.
pre15dale
- First Name: Dale
- Last Name: Kemmerer
- * REQUIRED* Type and Year of Model Ts owned: 1909 touring 1911 open runabout
I'm pretty sure I have a junk rim or two that has lugs on em I'll look next time I go to my storage
- Last Name: Juhl
A couple of times when I was prepping newly acquired rims for painting I've detected hairline cracks indicating lugs starting to come loose. Once you put a tire on it's hard to tell. If when you snug a rim in place the lug seems to be bending in too much it might bear checking out, even if you have to pull the tire. A good welder can repair them.
Some lugs have 2 tabs & some have 3 - I always "tack weld" the backside for safety.
