Rear Hub Reamer
Topic author - Posts: 56
- Last Name: Greger
Rear Hub Reamer
I am working on a Farm Tractor Co. of Fond Du Lac Wi. conversion and I am building the rear roller sprockets ( I have one 4 roller original for a pattern). I have the rough taper machined in and would like to know if anyone makes a finish taper reamer for the bore? Thank You for any help. Dan Greger
- First Name: Billy
- Last Name: Vrana
- * REQUIRED* Type and Year of Model Ts owned: '25 homemade pickup, Fond Du Lac conversion tractor
Re: Rear Hub Reamer
Can't help you with a ream, would it be possible to turn down a hub and build from that? Or maybe call the company,
- Last Name: Pharis
Re: Rear Hub Reamer
The tapers are a standard 3/4” per foot taper... I’m pretty sure that is measured per side, not included. The tricky part is getting the gauge point at the right dimension from the inner face. The drive key can be a challenge too. Good luck
Re: Rear Hub Reamer
Drop an appropriately sized ball bearing into the taper that you're cutting. Measure how far it goes in and compare that to the same measurement in a GOOD, stock, Model T rear hub.Kevin Pharis wrote: ↑Wed Jan 27, 2021 3:47 pmThe tricky part is getting the gauge point at the right dimension from the inner face.
It's possible to make the taper on a lathe, even one that doesn't have a taper attachment. It does however take a bit of tinkering to get it "dialed in ".
- Last Name: Pharis
Re: Rear Hub Reamer
Absolutely right...! Best to use 2 balls of different sizes to ensure the taper is correctly sized at both ends. And this introduces yet another tricky aspect... remembering to remove the ball bearings after each measurementJerry VanOoteghem wrote: ↑Wed Jan 27, 2021 3:52 pmDrop an appropriately sized ball bearing into the taper that you're cutting. Measure how far it goes in and compare that to the same measurement in a GOOD, stock, Model T rear hub.
- Last Name: Greger
Re: Rear Hub Reamer
Thank You All for your information, I never thought of using a ball in the tapered bore for getting the correct size, I will do just that. I turned a taper on a piece of round stock up and machined a 1/4 in. keyway in it to use as a mandrel to broach the key slot in the new sprockets. ----Dan Greger
- Last Name: Warren
Re: Rear Hub Reamer
- Last Name: Pharis
Re: Rear Hub Reamer
Good luck with the keyway... I started with a broach key and tapered mandrel, but found that I could not keep the assembly together while pushing the key from the small end, and the mandrel would pinch the broach key when pushing from the big end. I ended up building a fixture in my shaper to get the job done
- Last Name: Kramer
- * REQUIRED* Type and Year of Model Ts owned: 3
Re: Rear Hub Reamer
Dan. Sounds like a job for the boys at Kramer Power Equipment Jerry K
