What have you done with your T in February?
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Mon Feb 01, 2021 10:45 am
Starting to rebuild my rear axle as well...
Super Mario Bross ;)
1911 Touring
1914 Speedster
First Name: Adrian
Last Name: Whiteman
Re: What have you done with your T in February?
Post by A Whiteman » Mon Feb 01, 2021 2:57 pm
Panels all installed and a quick coat of primer. Trim and a 'bolt and nut patrol' to do then off for a compliance check for registration. So far I have the paper work sorted as well (which went very smoothly - but then our system sounds simpler than in the US).
Doors, windscreen, top and proper upholstery and proper paint in the 'next stages' of the plan.
She runs well too:
The attachment 21-02-01 (4).jpg is no longer available
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Mon Feb 01, 2021 3:00 pm
This was the car 11 days ago!!
Post by Steve Jelf » Mon Feb 01, 2021 9:44 pm
Today I finished my mag coil ring. It took months because I worked on it in spurts between other chores.
It's the first one of these I've ever done.
When I zapped it with twelve volts — WHAP! It grabbed that hacksaw blade like nobody's business, so I am a happy camper. It's not as pretty as some I've seen, but as long as it works I don't care if it's ugly as a mud fence.
The details are not all factory correct, but they're what was available, and it works.
AndreFordT
First Name: Andre
Last Name: Valkenaers
Post by AndreFordT » Tue Feb 02, 2021 1:44 am
Looking great Steve.
See you did a magnet test. Did you do a polarity test too?
The polarity test (N-S;N-S; ... 16 times) will tell you for 95% if your loop will work or not.
the 5% left has to do with the connections in the car and the way the magnets are charged. (weak -strong?)
Good luck
Andre
Belgium
Post by RajoRacer » Tue Feb 02, 2021 10:23 am
Working on a family owned TT - fellow was having some fuel issues - I think I found the problem !
ABoer
First Name: Anthonie
Last Name: Boer
* REQUIRED* Type and Year of Model Ts owned: 1912 touring 1923 roadster 1925 pickup
Post by ABoer » Tue Feb 02, 2021 10:46 am
How is that possible that he has FUEL PROBLEMS ??!!??!!
Toon
Post by RajoRacer » Tue Feb 02, 2021 10:56 am
I've gone through dozens of carbs in 40 + years & that's got to be one of the worst !!!
Last Name: Wrenn
Post by TWrenn » Tue Feb 02, 2021 11:35 am
I'll restart the fight over using Sta-Bil or not...I bet if this person used it in the fuel for layup it wouldnt be this way. Mine never are. And the '94 quit having annual spring issues once I started laying it up with Sta-Bil.
Post by RajoRacer » Tue Feb 02, 2021 11:44 am
This TT had been sitting in a shed untouched for 26 years - Gramps passed that long ago - believe it or not, I had it running in a couple hours WITH that carburetor - I even drove it in the fellow's parking lot !
Side note - all my "clear" gas gets Sta-Bil !
Post by Steve Jelf » Tue Feb 02, 2021 11:49 am
Yes, I did. N, S, N, S, N, S, etc.
This picture is also a warning against stupid hand cranking.
:D
Post by RajoRacer » Tue Feb 02, 2021 11:50 am
Nice job on the coil ring, Steve ! Knarly looking wrist though !
Post by Steve Jelf » Tue Feb 02, 2021 11:58 am
...believe it or not, I had it running in a couple hours WITH that carburetor...
When I got my '23 touring I found a similar situation. The car ran, but the carb leaked, so I opened it up and found a sight much like that. The leak was because of holes rusted through the bowl. The guys who "restored" the car did a fair job on the body, but ignored the mechanics.
Dropacent
Last Name: Morsher
Post by Dropacent » Tue Feb 02, 2021 12:10 pm
Hey Timmy, 94 octane non ethanol gas is available at Mickey Mart on rt250 not far from you. I keep it in everything old here now, and rest easy. It’s nice to have the racetrack close by, so they keep it there for those boys and girls. It’s like $3.50-4.00 a gallon, but worth every penny, IMHO. ESPECIALLY WITH NEW GAS TANKS NO LONGER AVAILABLE
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Tue Feb 02, 2021 8:20 pm
This is what I am not doing in February, except to maybe mail it off.
Vern (Vieux Carre)
John Warren
Last Name: Warren
Post by John Warren » Tue Feb 02, 2021 8:39 pm
Love the way your mag ring turned out Steve. Definitely lots of work. Looks well done.
Post by Steve Jelf » Wed Feb 03, 2021 12:16 pm
Looks well done.
I'm just glad it tested OK. :)
Vern, you may have to clean out the passages.
:D
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Wed Feb 03, 2021 9:49 pm
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sat Feb 06, 2021 7:27 pm
Well so far.., making progress here and there on the era/period correct boat trailer. Donnie and I got the axle mounted hugger fenders in pre mount.
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Sun Feb 07, 2021 1:37 pm
Well I have been having withdraw symptoms lately. Mud and rain was the weather this winter since I installed the RM brakes. Needing to do final adjustments it needed to be driven. Well I didnt do any adjustments, just checking for heat in rear drums and sevice brake and E brake. At 10 degrees there was no heat in RM bands so I took a little drive. I can adjust RM's when I have more traction and a little warmer conditions.
I think I may see some side curtians and manifold heater in my future.
Post by RajoRacer » Sun Feb 07, 2021 3:59 pm
Not mine but the same TT that carburetor overhauled - this old truck was "rode hard & put away wet" ! Haven't got the rear wheels off yet - next task.
Last Name: Hjortnaes
Post by DHort » Sun Feb 07, 2021 4:37 pm
Looks like Dallas has been driving up and down that field all day testing out those brakes. Surprised he isn't working on acceleration for his truck in case the Bishop shows up.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sun Feb 07, 2021 4:45 pm
The Bishop isn't a member of our club I think. He is just practicing knowing there is another snow coming to hide the evidence.
Hank
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Sun Feb 07, 2021 5:13 pm
Well truth is, church was next door this morning. I was just sizing up the competition of about 40 buggies parked there. Juice brakes, propane heaters and closed cabs. Looks like some real runners in the field to.😁
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sun Feb 07, 2021 5:18 pm
LMAO!!!!!!!!!!!!
Bill Dizer
First Name: Bill
Last Name: Dizer
Board Member Since: 2014
Post by Bill Dizer » Sun Feb 07, 2021 5:43 pm
Thot the TT was the race truck? Or is there a new "sleeper" race truck being introduced???? Looks like clandestine info gathering going on! Checking to see which horses have the ice spikes on their shoes for better traction? Tire chains for the truck? Enquiring minds want to know!!! Updates at eleven? :)
Post by Steve Jelf » Tue Feb 09, 2021 12:51 am
Gee, I actually accomplished something today. As the fleeting years bring increasing feebleness, I resort more and more to machinery in place of muscle.
The new piece of equipment I finished today is a magneto/flywheel/transmission lifter. It should ease the chore of getting the right magneto gap.
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Tue Feb 09, 2021 5:21 am
Woo hoo I registered (titled) and had the Colonial roadster legally tagged and put on the road today.
5 mins into our first run I blew up the muffler (see Luke's post on the subject). And you should have seen the cows run!
Many thanks to Luke and Chris for their help all hours of day and night to get the car on the road. Friends are great :-)
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Tue Feb 09, 2021 6:31 am
We finished cutting, priming and painting replacement wood for rear windshield and right stationary window on the '26 coupe.
Tacked 1-1/8" x 3/16" x 19-3/4" felt to rear window wood uprights.
Installed six corner window brackets (two made from stainless steel).
Mounted said wood for three rear windows with stainless, slot drive, flat head, #12 x 1" countersunk, wood screws after pre-drilling holes.
Mounted B-pillar to side window wood with stainless, slot drive, round head, #12 x 1-1/2" wood screws after pre-drilling holes.
Tacked wood to brackets and flanges with about fifty stainless #17 x 7/8" brads/nails.
Welded 8-) two brackets (made from scrap two years ago) at sub-frame and screwed top of each bracket to lower wood on side windows.
brackets and wood.jpg (30.63 KiB) Viewed 6286 times
Worked on seat back brackets, mounting crosspiece to two stands to hold in place while welding 8-) (from three brackets that were made from scrap two years ago).
Extracted two broken Henry steel #10 UNF machine screws from the B-pillar with the fire tool. ;)
broke screw fire tool.jpg (6.42 KiB) Viewed 6286 times
Vern (Vieux Carre)
Scott C.
Last Name: Clements
Post by Scott C. » Fri Feb 12, 2021 1:53 am
I pulled the cylinder head off the 26 Coupe to investigate why #3 cylinder was weak and found a burnt exhaust valve. After further inspection of other components I determined that it is time for a complete rebuild!!
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Sun Feb 28, 2021 4:29 pm
I think it hit 60 degrees today. I took the RPU and put it to work. Returning a concrete saw to a buddy. Nice drive without 4 layers of cloths.
Justbrett
First Name: Brett
Last Name: Hanus
* REQUIRED* Type and Year of Model Ts owned: 1921 center door
Post by Justbrett » Sun Feb 28, 2021 7:33 pm
[image][/image]
I cleaned, primed and painted 21 centerdoor...
Next is underbody inhibitor lube and reattach fenders and boards.
AndreFordT
First Name: Andre
Post by AndreFordT » Mon Mar 01, 2021 1:58 am
Finished the 1913 runabout.
Andre
Belgium
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Mon Mar 01, 2021 9:03 am
Congrats André! looking great.
1911 Touring
1914 Speedster
