'26 T popping and running hot
amarilloroger
First Name: Roger
Last Name: Jacobs
* REQUIRED* Type and Year of Model Ts owned: 1926 Touring Car
Post by amarilloroger » Sat Feb 06, 2021 5:02 pm
Started my T this morning and it ran rough, with a lot of popping and stalling. After a few minutes of running, the exhaust pipe turned red hot, so I killed it pretty quickly. It has a new Anderson timer and a Holley NH carb. Is the carb too lean? If so, why, since it ran great last Fall. Thank you!
Susanne
First Name: Susanne
Last Name: Rohner
Re: '26 T popping and running hot
Post by Susanne » Sat Feb 06, 2021 5:08 pm
Jellified (old) gasoline in the carb that keeps it from flowing... especially at the main jet. Also recheck your timing, especially since you replaced the timer. IIRC (someone correct me if I'm wrong) the Anderson timer is set using a different "gauge" than the stock Ford timer.
Post by Allan » Sat Feb 06, 2021 5:34 pm
A new Anderson timer often/always need to be re-timed. If you are running with the advance lever in it's old position, you are likely running too far retarded, hence the overheating.
Hope this helps.
Post by Norman Kling » Sat Feb 06, 2021 5:40 pm
Sounds to me that it is running lean or the spark is too retarded. I agree with the above. First two things to check would be timing with spark lever all the way up. Should be a few degrees after dead center. After the car starts, advancing the spark should speed up and smooth out the engine. Second check the carburetor richness. Try opening the needle about 1/2 turn counter clockwise from the present setting. Then start up the engine. As it warms up, lean by turning the needle clockwise. The engine should smooth out and then after you turn at a little more, begin to slow down. Back off the adjustment to the smoothest setting. You might need to do this every time you start up in cold weather.
In cold weather, you might need to start a bit richer until the engine warms up. If you are using a water pump without a thermostat, it might never warm up completely in cold weather. Another thing in cold weather which helps is the fuel heater which runs from mouth of the carburetor to the outside rear of the exhaust manifold. This will begin to work soon after starting the engine.
Another possible cause would be a sticking valve or not firing on one cylinder. All the unburnt gas will go out the exhaust and when it warms up, will burn in the manifold and cause it to become red hot. It is not good to run this way as there is a possibility of warping or burning the exhaust valves.
NealW
First Name: Neal
Last Name: Willford
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1929 Model A Tudor
Post by NealW » Sat Feb 06, 2021 11:19 pm
Last spring when I was putting our 15 runabout restoration back together, I did an experiment when I installed the Anderson timer comparing the timing using the 2 1/2" gage to the angle that my coils would buzz:
viewtopic.php?f=2&t=11879&p=88818#p88818
My experiment showed that the gage works for timing an Anderson timer, assuming that the tabs in the timer are bent to the proper angle.
A question for the original poster is if it ran fine last fall with the timer and carburetor currently installed, or if they were changed since the last time it was run. It was not clear to me from his original post.
Post by Allan » Sun Feb 07, 2021 4:22 am
I now run Anderson timers in three of my T's. Each needed adjustment to get it to behave as previous timers did. It could be done simply by running with the lever in different range on the quadrant. A better solution was to adjust the length of the rod connecting the timer to the control rod on the steering column. On out RHD cars with the timer hook-up at the bottom of the timer, I seem to remember the connecting rod had to be lengthened. Your LHD cars may be different.
amarilloroger
First Name: Roger
Last Name: Jacobs
Post by amarilloroger » Sun Feb 07, 2021 4:04 pm
Thanks everyone. I checked and my timing was way retarded. I used the timer setting tool used for stock Ford timers and found that it is way off for the ANCO timer. I adjusted the advance rod until the #1 coil buzzed a few degrees (roughly 15) past TDC with the advance lever fully retarded. Then I checked the remaining 3 cylinders. In addition, I found the #4 coil was weak so I replaced it with a spare I had. I would like to run it, but I have the carb soaking and waiting on a gasket set from Lang's.
On another subject, I got tired of buying crummy starter switches so I wired a 6 volt negative ground solenoid along with a horn button switch for a boat that I had laying around and my starting problems were solved. I mounted the boat horn switch in the stock Ford starter location in the floor, so it looks stock. I did learn that when it comes to 6 volt solenoids, there is a positive ground solenoid and a negative ground solenoid.
thanks,
roger
Post by Scott_Conger » Sun Feb 07, 2021 6:19 pm
Hopefully your seats are vinyl. If anyone ever attempts to steal your car and step on the boat horn, you will be glad they're vinyl.
jiminbartow
Last Name: Patrick
Post by jiminbartow » Sun Feb 07, 2021 10:24 pm
Are you running ethanol gas? If so, and you have not put in fresh gasoline since last season, there lies your problem. Drain he old gas and put in fresh gas. If using ethanol gas it has certainly gone bad, fouling the system.
TFan
First Name: Jim
Last Name: Riedy
* REQUIRED* Type and Year of Model Ts owned: 26 Roadster
Post by TFan » Sun Feb 07, 2021 11:40 pm
One thing I've not seen mentioned is, did you check the mag post for lint or possible breakage I understand that the symptoms you described sound a lot that could be it. Jim
amarilloroger
First Name: Roger
Last Name: Jacobs
Post by amarilloroger » Tue Feb 09, 2021 9:25 pm
I'll check the mag post this weekend. I'm sure gas isn't the problem since I only run ethanol-free gas and drain it after a month or so and the popping and hot running came on fresh out of the pump ethanol-free gas. As soon as my carb gasket set comes in, I'll get the carb back together and give it a shot. I'm pretty confident the way-retarded timing was the issue and the weak #4 coil didn't help either. Thanks for all the suggestions.
