23T crank pulley pin
				tommyleea
Topic author - Posts: 151
 - First Name: Tommy
 - Last Name: Russell
What is supposed to hold the crank pulley pin in place?  I see large hole/small hole in the pulley, and cotter pin hole in pin.  Is the pin supposed to fit tightly through the crankshaft to hold it in place, or does the pin enter the small hole tightly holding it in place?  I don't see any taper on the pin.  I have read several articles on the pulley and pin, but still not really sure what holds it in place.  Thanks.  I am at that point so trying to figure it out.  Tommy
Re: 23T crank pulley pin
The pin does fit tightly in the pulley. Many don't, and have to be knurled to fit properly. Don't mess with the small hole in the pulley. That is to keep the pin from coming out. The cotterpin in one end keeps the pin in place at the large hole end of the pulley.
Here's a picture of what Larry said. The parts are in poor condition, but they serve for illustration. The small hole in the pulley (left) is for punching out the pin when it needs to be removed. It is, or should be, too small for the pin to fit through it. The large hole (right) is for installing and removing the pin. A cotter pin in the end of the crank pulley pin keeps it from backing out of the large hole. You're right, the pin is not tapered.
				tommyleea
 - First Name: Tommy
So, with the pulley removed, I should have to tap the pin in, and it just goes up to the small hole, but not in it?Original Smith wrote: ↑Sun Feb 14, 2021 12:16 pmThe pin does fit tightly in the pulley. Many don't, and have to be knurled to fit properly. Don't mess with the small hole in the pulley. That is to keep the pin from coming out. The cotterpin in one end keeps the pin in place at the large hole end of the pulley.
				tommyleea
 - First Name: Tommy
Thanks..Thanks for the picture.Steve Jelf wrote: ↑Sun Feb 14, 2021 12:45 pmIMG_3836 copy.JPG
Correct. The small hole is only for a punch to drive out the pin when you remove it.
				tommyleea
 - First Name: Tommy
Took a look at mine today.  My pin seems to be much shorter than the diameter of the pulley, and it is not tight.  If it goes in tight, why do you need the cotter pin?  Not sure what is incorrect with mine.  Either the pin is too short, or the pulley is too large.  Are there different size pulleys?  I will take some pictures tomorrow.
You're not reading your emails, are you?
				tommyleea
 - First Name: Tommy
Just read it. Been in the shop all day..Thanks
Yes, there are different sizes.
Corey Walker
 - First Name: Corey
 - Last Name: Walker
Be sure and put in the cotter pin. I left one out one time and started the motor, I didn’t have a fan belt on it and that pin worked out and hit the pan. In addition to bending the pin, it made a tight pulley loose. A fan belt might hold it in place if it started to work itself out but I know I’ve had to come home without a belt for one reason or the other before.
Ford Service instructs and shows photo of cotter hole in the crank pulley pin, at the big hole end.  Place the crank pulley pin into the large pulley hole, with the cotter   hole of that pin up, facing the large pulley hole.
That cotter keeps the crank pulley pin from protruding out, wearing the fan belt, or worst, slipping out.
Although the pin is driven in and should be tight fit in both the crankshaft and pulley holes, the big crank pulley pin can get loose, wiggle, and move. Lots of stress on that pin with hand cranking.
The best way is always the simplest. The attics of the world are cluttered up with complicated failures.     Henry Ford
				tommyleea
 - First Name: Tommy
Thanks for the info.
Thanks..I will have to examine my parts some more. I think loose, wiggle, and moves sounds like the pin I have. TommyDanTreace wrote: ↑Mon Feb 15, 2021 9:14 amFord Service instructs and shows photo of cotter hole in the crank pulley pin, at the big hole end. Place the crank pulley pin into the large pulley hole, with the cotter hole of that pin up, facing the large pulley hole.
