hudco hogs head
donald4ham
First Name: Donald
Last Name: Goodwin
* REQUIRED* Type and Year of Model Ts owned: 1924 touring
hudco hogs head
Post by donald4ham » Mon Feb 15, 2021 10:52 am
There is a Hudco hogs head for sale, I am not familiar with these, how are they different from a Ford hogs head? The one pictured looks like it is for a 1926/27, is this correct?
Model T Tom
First Name: Thomas
Last Name: Butterworth
* REQUIRED* Type and Year of Model Ts owned: 1911 speedster
Re: hudco hogs head
Post by Model T Tom » Mon Feb 15, 2021 11:06 am
No pre 26 the pedal side unbolts and pedal side comes off.
Model T Tom
First Name: Thomas
Re: hudco hogs head
Post by Model T Tom » Mon Feb 15, 2021 11:09 am
Hope this helps
RGould1910
Last Name: Gould
Re: hudco hogs head
Post by RGould1910 » Mon Feb 15, 2021 12:19 pm
Hudco transmission covers are HEAVY. I sold one because I was concerned the weight would cause the pan to bend where the engine meets the cover. I would never consider using one with a four dip pan.
Re: hudco hogs head
Post by RajoRacer » Mon Feb 15, 2021 1:13 pm
I have one I intend to install when I remove the engine from the '19 Centerdoor IF I have to do bands again - anyone ever had the pleasure of installing bands in a Centerdoor ???? - !!!!!!!
I'm going to install the 4 dip corner reinforcements when I do - Richard - should remedy that concern.
Re: hudco hogs head
Post by Rich Eagle » Mon Feb 15, 2021 1:28 pm
I've never seen one. I'm not sure how many of us have. They are a delight to know about.
http://www.mtfca.com/discus/messages/80257/116389.html
http://www.mtfca.com/discus/messages/70 ... 1495367852
Last Name: Hatch
Re: hudco hogs head
Post by Dan Hatch » Mon Feb 15, 2021 3:34 pm
Hard to stop from leaking.
Luxford
First Name: Peter
Last Name: Kable
* REQUIRED* Type and Year of Model Ts owned: 1911 Town Car 1913 Speedster 1915 kampcar
Re: hudco hogs head
Post by Luxford » Tue Feb 16, 2021 5:22 pm
I saw one of these at a Swap meet in California over 30 years ago.
So I decided to make one as our cars are RHD. It only ended up adding a few ounces more that an original hogshead.
If you use a hack saw blade to cut the section out there is only the thickness of the blade to seal off.
I used a flat piece of steel about 1 1/2" wide 1/4" flat and formed it in sections around the area to be cut straddling the position of the proposed cut
The sections were then drilled and tapped on either side of where the cut was to be and they were bolted to the hogshead.
Each section was welded to the one next to it. The steel strap was then removed and a hacksaw used to cut in the center between the tapped holes.
The cut out section was then bolted to the steel and the heads cut off. I had the steel brazed to the cut out section but using JB Weld would work too.
It was then only a matter of drilling the other holes for clearance for the bolts in the removed section and it can then be bolted to the hogshead again.
This leaves just the thickness of the hacksaw blade and the overlapping of the flat steel makes it easy to apply a sealer, it never leaks.
Ideal for a Centerdoor or any T which is hard to get to the bands, it can be unbolted and removed in minutes, and is easy to put back in especially getting the band ears around the pedal shafts. An ideal winter job for someone with a few basic tools.
Re: hudco hogs head
Post by RajoRacer » Tue Feb 16, 2021 6:02 pm
Well, that was certainly an endeavor worth pursuing !
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: hudco hogs head
Post by Dan McEachern » Wed Feb 17, 2021 3:24 am
Steve- you could go into business making these hogs heads! :mrgreen:
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Board Member Since: 2010
Re: hudco hogs head
Post by Charlie B in N.J. » Wed Feb 17, 2021 8:19 am
Well... There’s the “thing I learned today”. First for me.
Last Name: Wrenn
Re: hudco hogs head
Post by TWrenn » Wed Feb 17, 2021 9:04 am
Me too Charlie. That's what I like about this forum and the hobby...always something new to learn. Almost daily.
And as for a Centerdoor...since I don't have nor desire one, I never realized of course the difficulty in getting at the bands.
But thinking about it, now I can see why. I have a friend who would like one, I wonder if he knows or thought about this...I'll have to ask him!
