Learning how to post photos---This is a trial
Topic author - Posts: 892
- First Name: Bruce
- Last Name: Brakke
I am learning how to post pics. I hope this works!!
- First Name: CHARLIE
- Last Name: BRANCA
- Board Member Since: 2010
Re: Learning how to post photos---This is a trial
I simply have not been able to do this with Win 10. Probably easy enough just not enough between the ears. I now have an IPad in addition to the pc. Would that perhaps be easier?
- First Name: Dennis
- Last Name: Seth
Bruce,
That is not a trial... It's a sulky plow!
- First Name: Bruce
- Last Name: Brakke
IT WORKED!!!!!! Yes, it is a John Deere Gilpin Sulky Plow which was first built in 1875. I have one just like the one in the picture. I will try to send a picture of it before I restored it. Hopefully, I can repeat the process!!
The process to post photos is basically independent of the computer that is being used. (phones a bit harder). Not sure what problem you are having.Charlie B in N.J. wrote: ↑Mon Feb 22, 2021 6:41 pmI simply have not been able to do this with Win 10. Probably easy enough just not enough between the ears. I now have an IPad in addition to the pc. Would that perhaps be easier?
Start a post. enter text.. then Click an the Attachment Tab, ten when you see ADD FILES click on it - now that action opens up a window showing the folders and files you have on your computer and that is computer dependent. Once selected you need to wait a bit fir it to be uploaded to your post - when you see Place In line - you can add a a max of 5 photos to one message - if more photos just start another REPLY in the same POST.
If you having trouble finding the photo on your computer or a something else email me I'll be glad to help
I'll add that you can post nearly all full-sized pictures and the forum software will make them fit. Rarely you will get the dreaded yellow triangle and the notice that your picture is too big. In those cases I find a slight reduction good enough.
This is 1.3 MB, 2533 × 2905 pixels, and it posts easily with no need to resize.
- First Name: Rich
- Last Name: Jesteadt
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1913 Touring project w. "A" crank shaft
I can't make a P M go thru , seems to get hung up in out box ,can anyone make any suggestions. It probably has a lot to do with my lack of teck knowledge. !!!
- First Name: Rudy
- Last Name: Rathert
- * REQUIRED* Type and Year of Model Ts owned: 1909 1913 1914 1915 1926
Looking good Bruce now if you would come back to Forman and show me how to do it Rudy
- Last Name: BRANCA
Test. Giving it a shot.
No good. Says 3mb and the aforementioned triangle appears. Too big? Small?
- Last Name: Warren
- Last Name: Warren
Now days my smart phone is my camera, the new forum is very friendly posting photos directly from my phone.
- Last Name: BRANCA
let's see. This is on the Win 10 laptop....(this writing is edited on after posting the pic: seems drag & drop works on the PC.) Thanks Frank.
Second text edit; still no on the IPad. 3mb and the triangle.
- First Name: Tony
- Last Name: Bowker
On my postings the yellow triangle means the picture is too large. The site moderators told me the problem had been resolved and it hasn’t happened to me since.
If your problem occurred recently then you may have exceeded the new limit. Try making your pictures smaller. On my laptop and my iPhone, I have applications that do it. Another way on an iPhone is to mail the picture to yourself and choose a smaller option when asked.
Tony Bowker
La Mesa, California
La Mesa, California
- First Name: Bruce
- Last Name: Brakke
I have encountered one odd thing. If I take a photo with my phone camera held in the horizontal position, I can post it. However, if I hold the camera vertically taking a photo of the same object, it does not post. Any thoughts on why?
There are several possibilities. What make and model phone? Does it have different modes like PICTURE, LANDSCAPE, PORTRAIT etc What di you use for each photo. Yes post the one you can
