How to test a coil with a multi meter
Rata Road
Topic author - Posts: 210
- First Name: Kevin
- Last Name: Weeds
- * REQUIRED* Type and Year of Model Ts owned: 1923 Depot Hack, 1927 Coupe & 1914 Runabout
Long ago I had a problem with a miss in my Depot Hack and tracked it to one coil not working.
So for several years I have taken one coil from my speedster or my Coupe when I want to drive the Hack.
This year every night I take a different T for approx 45 mins drive around most streets in our small town, so each car gets a good run every 3 days but I was getting sick of the constant coil swap and have now managed to get some more coils.
Yesterday I decided to look up how to bench test a coil lighting a spark plug and to my surprise all coils light the plug including the faulty coil?
Maybe it just needed a contacts clean or the fact I used a 12v test battery as the car is 6v and the mag wasn't very good so I ran the car on battery.
(Mag since fixed using the 3 battery in line spark method), now it runs fine on Mag. I havent tried putting that faulty coil back in.
However I would like to ohm test each coil, I see some you-tube clips showing how but they don’t explain what settings I would need on the multi meter. I have a Fluke meter.
Can someone please explain –
1. Where to take each reading
2. What the reading should be for each particular test
3. And how do I set the meter for each test if the setting is different
4. Also does it matter when doing a bench test looking at visible spark on a good spark plug whether the coil is connected to a 12v battery v a 6v
Kevin
Kevin
Re: How to test a coil with a multi meter
I was learned by Ron Patterson that you set your analog ohm meter to 1K - touch one lead to either contact & the other to the other on the side of the coil and the reading should be in the 3200 ohms +/- 10% IF I remember correctly.
Art M
- First Name: Art
- Last Name: Mirtes
:i suspect that the capacitor is defective. This can be checked with a capacitor meter, which are available on line at a very affordable price. I have one and have found that all of my coils needed new capacitors.
They are kind of messy to dig out but after doing several it gets easier. Or you can send them to a rebuild.
Art Mirtes
Art Mirtes
Rata Road
- First Name: Kevin
- Last Name: Weeds
Thats interesting Art.
Steve can you please clarify exactly where you test, lets say one button teminal is on the bottom, two buttons are on the side lets say higher & Lower.
Kevin
Kevin
You test the two side buttons. In most cases, if the coils passes the ohms test it is likely re-buildable.
Rata Road
- First Name: Kevin
- Last Name: Weeds
So this test only tells you if the coil is rebuildable? I was hoping it would tell me if the coil is in good condition.
Tell me - If a coil makes a good spark on a test bed spark plug is it possible that this coil wont be good enough in the car?
I have just enough coil knowledge to be dangerous - hopefully Ron Patterson or one of the several "expert" coil gurus will assist you in your quest !
KBurket
- First Name: K
- Last Name: Burket
One of Ron Patterson’s old posts includes a pdf showing the ohm meter measurements.
http://www.mtfca.com/discus/messages/80 ... 1252887023
There’s other discussions, one in Tinkering Tips Vol 2 I believe.
MKossor
- First Name: Mike
- Last Name: Kossor
Here is a video link to the MTFCA Coil Testing and Tuning Webinar I presented last year that you may find of interest. It is a bit long but covers a lot of information. You can skip around to the areas of interest or watch the whole thing.
https://youtu.be/RYcGD-8Ol3s?t=364
Let me know if you have any specific questions.
Rata Road
- First Name: Kevin
- Last Name: Weeds
Thanks Kevin,
thats a help.
Kevin
thats a help.
Kevin
Rata Road
- First Name: Kevin
- Last Name: Weeds
Thanks Mike, I'll watch this then get back
Kevin
Kevin
Rata Road
- First Name: Kevin
- Last Name: Weeds
Mike the webinar was interesting but a bit heavy for me.
I see nobody answered number 4 question above but today I discovered the answer myself.
I cleaned the timers on 2 of my T's today and noticed one car wasn't running right so I cleaned the coils/coil box etc but no improvement.
I grabbed a screwdriver and I noticed no 3 wasn't affected when the plug was shorted out.
I fitted a spare plug and lay on the head....turned the crank...good spark.
I removed the existing plug, cleaned it up, lay that on the head and good spark.
So I refitted original plug, started the car with no improvement and still no effect when shorted out.
So I replaced that coil.
Ran nice and when tested I lost a cylinder when each plug was shorted out.
Moral of the story - A coil that can make a spark plug buzz and look good to the eye doesn't mean it will run smooth in the car.
Matt in California
- First Name: Matt
- Last Name: G
I prefer this chart that John Carter developed for simple multi-meter tests:
Also a couple years back I made the following. I need to update it, but you may find it helpful.
attachment=0]Model T Adjustment 3_7_21.pdf[/attachment]
Matt[
Matt[
- Attachments
- Model T Adjustment 3_7_21.pdf
- (6.47 MiB) Downloaded 177 times
Last edited by Matt in California on Sun Mar 07, 2021 11:22 pm, edited 3 times in total.
Rata Road
- First Name: Kevin
- Last Name: Weeds
Matt, heaps of good info in your attachment.
MKossor
- First Name: Mike
- Last Name: Kossor
Yes, indeed; there is a lot too it but well worth the time and effort to learn and understand.Moral of the story - A coil that can make a spark plug buzz and look good to the eye doesn't mean it will run smooth in the car.
That test merely indicates each coil if firing. There is a Huge difference between a Model T engine that "runs" and one that runs well. The difference is largely dependent upon on ignition Timing to which the coils play an integral role. Unfortunately, you can't adjust coils to all fire spark after the same dwell Time and do so consistently using a multi meter. You can email me (mictel at comcast dot net) if you would like to know more; I can't discuss more here because I developed and market tools used to make the job easy.Ran nice and when tested I lost a cylinder when each plug was shorted out.
jab35
- Last Name: Bartsch
Matt: That's an excellent article. Information like this should be incorporated into the mtfca booklet "The Electrical System" jb
MKossor
- First Name: Mike
- Last Name: Kossor
Matt,
I noticed a few links in your Model T Coil notes are broken due to WebSite updates. Here are the present links to those references:
Reference 5:
https://img1.wsimg.com/blobby/go/f76807 ... 6881770750
Reference 8:
These links should be valid for some time.
Reference 5:
Reference 8:
Matt in California
- First Name: Matt
- Last Name: G
Kevin,
I am glad that you found this helpful!
James,
As you can see nothing stated in the article is original, but I did find that I had to search around for stuff. I have posted it in the past, but it didn't get much traction. I laugh because no one has called out the $2940 5/16" Head #12-32 Jam Nuts
I think that people just havn't looked at it carefully.
(The idea with the nuts is that you have to make your own or just by a kit for $1.50 from a distributor, but if you live on the other side of the world that may not be the best option.)
Mike,
Thanks for sending the updated links! I updated the document above. On reference five I was referring to: Electrically Cranked Coil Tester Instruction Manual. You listed the software install manual.
Matt
James,
Mike,
Matt
MKossor
- First Name: Mike
- Last Name: Kossor
Matt, My Bad. Reference 5 should have been: https://img1.wsimg.com/blobby/go/f76807 ... 5263743238
