air filter
Rod Petrie
First Name: Rod
Last Name: Petrie
* REQUIRED* Type and Year of Model Ts owned: 1926 TT
air filter
Post by Rod Petrie » Thu Mar 18, 2021 8:43 am
After 13 months I got my 26TT engine back from Lillikers. With the help of a young friend we are starting to put things back together. When we put the carb on he says "No air filter?" I would like the forum members opinions on air filters.
Re: air filter
Post by John kuehn » Thu Mar 18, 2021 9:06 am
Model T’s did not come with air filters when they were built. It’s not a factory item. It’s your car and if you want to add one go ahead as some T owners do it for peace of mind. Unless you drive your car on dusty dirt roads you don’t need one. T’s needed them more then then they do now. Opinions will vary without a doubt.
Others will have different ideas about it just as they do about oil, type of transmission bands, and other things.
Re: air filter
Post by TRDxB2 » Thu Mar 18, 2021 11:25 am
Model T’s did not come with air filters when they were built. It’s not a factory item....... you drive your car on dusty dirt roads you don’t need one. T’s needed them more then then they do now. Opinions will vary without a doubt. ...
NE dusty roads? You can always take it off when you want to be period correct ;)
Re: air filter
Post by Scott_Conger » Thu Mar 18, 2021 11:49 am
Rod
check your email
SurfCityGene
First Name: Gene
Last Name: Carrothers
Re: air filter
Post by SurfCityGene » Fri Mar 19, 2021 12:23 am
I would guess that you might have replaced the filter in your modern car and seen all the debris that's gets trapped there.
I don't want that dirt going thru my T engine so I have installed a filter. Most people don't even notice.. YMMV
1912 Torpedo Roadster
ModelTWoods
First Name: Terry
Last Name: Woods
Re: air filter
Post by ModelTWoods » Fri Mar 19, 2021 12:31 am
Will any of the currently available from vendors, air filters fit a Stromberg OF-!?
Re: air filter
Post by TRDxB2 » Fri Mar 19, 2021 12:59 am
Searched MTFCA and found this post http://www.mtfca.com/discus/messages/17 ... 1298811126
By Michael Pawelek on Wednesday, February 23, 2011 - 08:56 am:
I bought this set up from Snyder's a few years back and it works perfectly. I drive a lot of dusty back roads with my '19 and for the huge expense of having the engine rebuilt would never consider running any engine without an air filter. With the Stromberg OF carburetor and "Z" head this engine purrs at idle to 45 mph.
Snyders listed lots of styles Model T & Model A https://www.snydersantiqueauto.com/Sear ... r%20filter
Would guess that this is readily available from other sources like autparts stores
