On our 1923 TT, on the front axle it has model T wheels and rims with 4 bolts, on the rear axle it has the usual demountable rims. (6 bolts)
Is that correct? What is the correct tyre size for the front axle of a TT? Should it be 30x3,5 or heavier? Now it has tyres 820x120 (millimeters) which is the same as 32,3x4,73.
Wheel size Model TT
Peter_verweij
Topic author - Posts: 2
- First Name: Peter
- Last Name: Verweij
- * REQUIRED* Type and Year of Model Ts owned: TT1923; Touring1923
- First Name: Adrian
- Last Name: Whiteman
Re: Wheel size Model TT
Rear wheels are much heavier than front and different size. They are 20" .
The rim demountable but is a two part with a lock ring. Best to inflate these in a cage (see a google search on lock ring tyre dangers).
The rear axle is much larger and the hub is a heavier part - they are not compatible with car wheels, nor are car tyres possible to fit on a TT rim.
Your rear tyre size is not standard TT, was this size used in European produced TTs?
Bud Delong
- First Name: Kenneth
- Last Name: DeLong
There were two TT's on the farm long ago and 60 years years ago there was a 32x6 new tire in the straw mow for one of the tt's.Bud.
A 1923 TT would have had 30 x 3.5 tires on the front with 32 x 4.5 on the rears from the factory - rears could have been changed out or replaced with a 6.00 x 20 - please post a photo for positive ID.
