tire mounting powder
Topic author - Posts: 181
- First Name: Jim
- Last Name: Sims
- * REQUIRED* Type and Year of Model Ts owned: 17 touring 20 roadster 21coupe 25tudor 25 pickup 27 coupe
Where can I buy the tire mount talcum powder? Where I live, no one has even heard of talcum powder.
- First Name: Erik
- Last Name: Johnson
Re: tire mounting powder
You should be able to buy tire talc at an auto parts store like NAPA, a tire supply or your local fleet and farm store, etc.
O'Reilly Auto Parts carries it:
https://www.oreillyauto.com/detail/c/xt ... xts0/14550
One large canister will last you a lifetime. I have a can on the shelf that is about 40 years old.
General google search for "tire talc":
https://www.google.com/search?q=%22tire ... e&ie=UTF-8
Note: some folks use baby powder but be aware that baby powder no longer contains talcum. It is mainly corn starch.
This is where I got mine; https://www.aircraftspruce.com/neworderform.php
- First Name: Bill
- Last Name: Mullins
You can use a product called Rubber Glyide that you can get at NAPA stores.
- First Name: Colin
- Last Name: Mavins
I use dish soap works well and the excess dries up to a powder I use sunlight soap it does not harm the rubber.
I also use baby powder. Didnt know the difference.
Is there a reason/advantage to get the right stuff (talcum powder)??????????
If it matters, i will get the talc.
- First Name: Rich
- Last Name: Bingham
Talc (aka soapstone) is a mineral. Its lubricating quality owes to the plate-like structure of particles when pulverized. It used to be a common ingredient in bath powders and baby powder until inhalation was linked to cancer. (Isn't everything ?). Any road, "baby powder" if available at all is currently other stuff, primarily corn starch. I've no idea if its properties give similar results in a tire.
To clarify, dusting the inside of a tire with talc is a good idea as it prevents the innertube from chafing and/or sticking to the tire casing. Used to be new innertubes came liberally dusted with an application of talc. This kind of lubrication has nothing to do with getting the tire bead to slip over the rim as we wrestle to mount a tire.
"Get a horse !"
Yea good catch. Talc/baby powder inside tire.
Soapy water to mount the tire.
Have also used wd-40 also to mount tires on the road.
- First Name: Mario
- Last Name: Brossard
I used Baby powder several year either. Work really well. Able to change the tire in 10 minutes.
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
- First Name: R.V.
- Last Name: Anderson
Dish soap works well but it will rust the rims if you leave the residue on the rim.
- First Name: Bob
- Last Name: Bishop
What kind of powder do we use to get the old tire of???
Bob Bishop
San Diego, CA
1914 touring, 1917 touring
San Diego, CA
- First Name: Kevin
- Last Name: Matthiesen
Bob, To answer your question on tire removal. Triple fine black power could work, but I wouldn't recommend using it, due to the colardial damage. lol
My buddy worked at a Harley tire shop - he used Windex for quick tire removal.
- Last Name: Wendt
- * REQUIRED* Type and Year of Model Ts owned: 1926 Fordor
Huh....I just watched the video over the weekend and don't recall any use of powder in the MTFCA 1-3 Model T tires-II featuring Fred Houston. In the video the tires mounted on the featured split rims and wire wheels slick with Ru-glyde.
- First Name: Bob
- Last Name: Bishop
Steve-I'll give the Windex a try. Thank you.
Kevin- I've been trying to remove this rear tire for almost a year. It's 20 years old and hard as cement! Black powder is sounding better and better!
Realistically, I'm thinking of a Sawz-All, but don't have one. Made the mistake of telling the Rental place what I was going to use it for and they
refused to rent it to me.
Had a friend who mistakenly drove his car with a flat tire and the tire, tube, and flap came right off. No damage. Was remounted. I don't care
about damage (I have a new tire, tube, and flap I want to put on). I've driven it around the block, flat, several times and it just hangs in there,
no problem, doesn't budge!!!
Sorry, didn't mean to hijack the post.
Bob Bishop
San Diego, CA
San Diego, CA
I can't remember the last time I ever saw a tyre shop use talcum to mount any tyres. You'd think they would get with the program! That stuff they brush on can't be doing much good to the bristles on the brush.
I use Go-Jo hand cleaner or what ever hand cleaner that I happen to have. It works well and super slick. Cleans your hands up too!
- First Name: Bryan
- Last Name: Ostergren
- * REQUIRED* Type and Year of Model Ts owned: 1914 cut-off touring/pickup: 1922 Touring car: 1921 TT Dump Truck
For what my experience is worth, I've used corn starch for years. Seems to work as well as talcum for me. The wife (if you have one) probably has some in the pantry. Plus, it's "natural" and you can lick your fingers clean when you're done.
- First Name: Martynn
- Last Name: Vowell
- Board Member Since: 2012
Derrick Pang and I used WD-40 when we mounted his new tires for his 16...they went on easy in about 10 minuets each, flaps and all.
Fun never quits!
- First Name: Terry
- Last Name: Woods
RuGlide is a liquid lubricant, applied with a paint brush or clean rag. Fred Houston used it in the MTFCA tire mount videos and swore by it.Bill Mullins wrote: ↑Tue Mar 30, 2021 11:45 amYou can use a product called Rubber Glyide that you can get at NAPA stores.
- First Name: Jim
- Last Name: Sims
I should have made it clear I am mounting 21 inch split rim tires and a liquid lube is not wanted.
- First Name: Mario
Sometime tires are so hard and dry you do not have choice to use a saw... Seriously, that happen to me. But be careful to do not damage the Rim...rbishop26 wrote: ↑Tue Mar 30, 2021 6:13 pmSteve-I'll give the Windex a try. Thank you.
Kevin- I've been trying to remove this rear tire for almost a year. It's 20 years old and hard as cement! Black powder is sounding better and better!![]()
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
- Last Name: Hatch
Check out my ad on classified page. Dan
- Last Name: Bartsch
Jim: You don't need any powder, go jo, etc to mount 21' tires, tubes, flaps on 21' split rims. The rims collapse sufficiently that the tires just slip on, and once everything is aligned the rim can be expanded and locked without using any lube/powder. jb
- First Name: Terry
- Last Name: Woods
Jim, I just got through mounting SEVEN 21" tires on SEVEN split rims, and because the rim can collapse, I didn't need any lubricant of any type. Naturally when mounting clinchers or drop center wires one or the other type would be needed.
I have found using the split rims, when expanding the rim, the rubber valve stem wants to move and pull out of the hole in the rim. The talc should help in keeping the tube where it needs to be allowing it to slide inside the tire. This may not have been an issue with metal stems, but the rubber type are not locked into place.
- First Name: Ignacio
- Last Name: Valdes
New flaps and tubes from Lang's come with oil on them. I wonder why and what kind of oil is it? So I did not use powder on them and they go in easily.
- First Name: Kenneth
- Last Name: Todd
Anyone ever try/use red rubber grease?
https://www.google.com/search?q=red+rub ... e&ie=UTF-8
Might be something like silicon type lube used as a mold release.
