I have a Model T project underway and need a left hand shifter on the Ruckstell.
A couple of questions:
1) Does the kit the vendors sell completely replace the normal shifter that attaches to the back of the transmission?
2) Would it be possible to modify the left hand shifting kit to move the shift handle further outboard?
This shifter will be on Rosalie's brass firetruck and entry from the driver's side will be restricted by the ladders so an
outboard shifter will not be in the way. Moving it a further 6 inches from the emergency brake hole solves a couple of
issues in construction.
Thank you for your help,
Harry
Ruckstell Left Hand Mount Shifter
Topic author - Posts: 327
- First Name: Harry
- Last Name: Lillo
- * REQUIRED* Type and Year of Model Ts owned: Speedsters, racers, depot hack, coupe
Re: Ruckstell Left Hand Mount Shifter
I would venture to say "Yes" & "Yes".
- First Name: Craig
- Last Name: Vechorik
- * REQUIRED* Type and Year of Model Ts owned: 1915 Touring, 1922 coupe
When installed in the car, it looks like this:
"If a fly can, a flywheel"
- First Name: Mike
- Last Name: Walker
Hi, Harry -- I have used the one from Snyder's in 2 or 3 cars and like it a lot. (I don't know whether Lang's is the same or not.) Yes, it does replace the entire center mechanism. I made the rod to the rear end from electrical conduit in one piece, rather than using a 2-piece one. Once you get things situated, you'll need to weld the arm to the shaft so it can't move. It doesn't take much.
In our RHD cars, the standard shifter is left handed anyway but it is still not much help because the throttle lever is also on the left of the steering quadrant. Rather than make up a RH shifter with all its complications, I added a foot throttle. Dead easy on a RHD car, but a little more complicated on a LHD.
