Vibration Question
Topic author - Posts: 220
- First Name: Joshua
- Last Name: Powers
- * REQUIRED* Type and Year of Model Ts owned: 1922 Center Door Sedan
Vibration Question
On my 27 Tudor, I have a vibration that I am hoping to diagnose. Moments after you first shift into high and only for a few seconds I have an awful vibration that rattles the whole car but as I accelerate it quickly goes away. It doesn't seem to have anything to do with the shifting itself because whenever I slow down to a similar speed with the car still in high the vibration returns but goes away as soon as I accelerate again. The vibration is also present at the top end of the speed (usually going down hill). The car pulls hills without issue and has plenty of power. It doesn't vibrate under a load, just at these specific times.
Any ideas?
Thanks and God Bless,
Joshua A. Powers
Any ideas?
Joshua A. Powers
Re: Vibration Question
It is possible it might be "harmonic vibration" At certain speeds an engine tends to vibrate. Lower or higher speeds it does not. The only correction for that condition would be to disassemble the entire engine and transmission and balance all the parts.
Another possibility would be fuel mixture at idle. When you first shift, the engine is idling, but when you increase the throttle, you open the air flow through the main body of the carburetor. When the throttle is closed you are using the idle passages. Also when you are going downhill, you close the throttle and again drawing fuel mixture through the idle passage.
- Last Name: Juhl
Sounds like my car.... Driving a T is seems like it's missing a gear between low and high. My solution is to speed up a bit more before shifting to high. I also noticed when I switched from a 11 tooth pinion to a 10 tooth that the speed range where that happens narrows.
I had a similar situation i assumed to be a harmonic.
Accelerating on the freeway. @ about 53mph wouldnt go any faster & vibrated horribly. I found that retarding spark & slowly abvancing, I could get past this rough spot to get to 60. (this is a 100% balanced everything motor.)
After breaking the crank. (mint shermike - surebreak) I put in a scat crank. I still get a harmonic vibration. Now @ 58mph. That works better.
When i am in a hurry 55 is a comfortable speed.
Try the retard trick @ hi speed.
- First Name: Kenneth
- Last Name: Todd
It sounds like the spark may be too far advanced, have you tried adjusting (retarding) the spark when you shift?
- First Name: Henry
- Last Name: Lee
Sometimes your clutch dogs hang up too causing a similar condition.
Hank
Hank
A bad U-joint or loose driveshaft bushings could cause that. So could a dry U-joint. Loose bolts anywhere in the driveline, loose or damaged pulleys, loose motor mounts, loose rear hubs, problems in the transmission, and more could cause it. From here, I'm best-guessing it could be an issue relating to the U-joint or loose bolts holding the U-joint ball housing together. If you can duplicate the vibration by varying the engine speed with the clutch disengaged and the car standing still, it would suggest an internal problem with the engine/transmission or a loose motor mount.
- Last Name: Matthiesen
Your vibration happens when the car is driving the engine, on the low to high gear change, on the high to low gear change, and going down hills. This could be caused by drive shaft fore & aft movement, the ring gear negative load pushes the pinion forward a little on the shift or down hill load. On a level road try slowing down more gradually to the low gear change. On the low to high up shift try accelerating a little slower. Make sure to retard the spark for the up shift and then advance the spark on acceleration. Does this change the vibration any ? If it does then the problem could be in the drive shaft. The modern type drive shaft spool, ( fun products type ) deals with movement better, but the stock T system works ok if it is in good condition.
Do you have the side bolts & wood blocks in your engine mounts? Many times, the lack of them can cause big vibrations.
- First Name: Barry
- Last Name: Loucks
- * REQUIRED* Type and Year of Model Ts owned: 13, 22
Bad U-joint? They cause vibration upon deceleration in a more modern conveyance?
- Last Name: Dow
Do I really need the vibration dampening mounting blocks? I'm installing a newly rebuilt engine & transmission which has had all components carefully balanced and the crank replaced with a Scat Crank. The blocks are a pain to install and I'd just like to omit them. Your thoughts please.
- First Name: Jack
- Last Name: Putnam
Put the blocks in. Henry did it for a reason. He could have save $$$. He didn't because they were needed.
Upper bolts go in first. I have been using longer bolts & adding a radius rod spring to tension, but not ridgidize the mount.
Block top notch clears the heads,
Trim the blocks enough to slide in easy. Consult T1 on tightening.(or not tight??)
Those blocks avoid side sway of the crankcase. The upper two bolts are tight which holds the ears to the frame, so any sway will work the metal and fatigue will set in breaking the ears off. The blocks will prevent this.
Have you compared this T to others. They all have some vibration when the engine is going slow. If you rev a bit more in low before you shift, does it still vibrate in high? I wish I could diagnose it in person, but hard to do so on line without experiencing personally.
- First Name: Michael
- Last Name: Pawelek
All three Model T’s I have owned have had a vibration at a certain rpm range though I do not know exactly what rpm it is/was. It has never been bad and generally only noticed in “blurry” rear view mirrors. All three have had holes drilled in the flywheels for balance but no other parts were balanced in the rebuild process.
- First Name: Bob
- Last Name: Coiro
- Board Member Since: 2009
Every Model T I've driven behaves that way. The car needs an intermediate gear between low and high, but of course doesn't have it. Make a habit of accelerating gently until you're out of that pesky vibration range.
- First Name: Dick
- Last Name: Cruickshank
Experience tells me that you have a bad U-joint.
- First Name: Dick
I forgot to add in my response, please when you find the problem tell us what it is/was. We don't learn if we are not told. Thanks!!
