Powder Coat or Paint My 1927 Coupe Frame/Axles/Wheels?
BLB27
Topic author - Posts: 892
- First Name: Bruce
- Last Name: Brakke
I planned to have the frame/axles/wheels blast cleaned and then brush paint them using Rust-Oleum primer and Rust-Oleum black gloss. However, I now am considering having them powder coated. I would appreciate members commenting on these two options.
- Last Name: Patrick
Re: Powder Coat or Paint My 1927 Coupe Frame/Axles/Wheels?
In your post of March 30, on this same subject, you received 27 responses on painting your frame. I respectfully suggest you review your prior post on this to get the answer you seek. I doubt that much more can be added. Good luck. Jim Patrick
I have a more recent observation since the earlier discussion. Over twenty years ago I had to replace the wood on a back yard swing my uncle made before the war. I painted the metal parts with rattle can Rustoleum, which needs no primer. This swing sits outside, rain or shine, summer and winter, through all weather. Today I noticed that over twenty years later, the paint on those metal parts is still doing its job, looking as it always has, with no rust and no flaking.
My second comment is just opinion and hasn't changed. Despite originality and practicality, I still prefer a satin finish for chassis parts, especially the engine. I painted an engine glossy, and hated the way it looked, so I gave it a coat of satin and like that much better. For wheels and body, I go with glossy.
dmdeaton
- First Name: Danny
- Last Name: Deaton
I powder coated my frame on my 27 and will not do it again. I painted everything else that bolted to it. If you need to refinish or sand to bare metal it’s a chore. It melts. Just my opinion
- Last Name: Hatch
If you had power coating that melted or rolled up when you sanded it, sounds like it was not cured. Try a MEK rub to see it takes it off. If so, paint is not cured.
Today’s appliances are made from precoated coils. The forming is done after the steel is painted. Dan
Refer to the March 30th post. Lots of information on the subject already to make the decision. Good luck.
ThreePedalTapDancer
- First Name: Ed
- Last Name: Martin
I have had multiple frames powder coated. You can pick any combination of gloss, all the way to flat sheen. A proper powder coating company will sandblast the frame and parts to bare metal, and uniformly apply the powder to achieve a nice even finish. All surfaces and threaded holes you want to be powder free will need to be masked by the powdercoater. It’s a nice time saving method of chassis restoration, and it’s wonderful putting a freshly powder coated chassis back together.
The decision on what method to paint the chassis depends on your objectives (show or go). I took my chassis to be sand blasted and just primer-ed to prevent rusting. It was sort of chick and egg decision. There was some things left to do that would require welding or riveting and some pit marks to take care of and thought it would be easier to do those things with a sandblasted chassis. When I went to pickup the chassis they had powered coated the chassis with a primer coat and just paint primer-ed the rear axle housing and torque tube. The bill was about double. I lost the argument.
The first point I am trying to make is what needs to be done to the chassis and in what sequence - the last step is paint. The second point is how do you plan to use the T once its done and how will it be stored when not in use. In other words, what benefit will it (paint or powder coat) provide the T in the next 20 years.
I will only powder coat wire wheels & rims.
ThreePedalTapDancer
- First Name: Ed
- Last Name: Martin
As for longevity, I had my Model A chassis powder coated gloss black 20 years ago. It looks like it did when it was done, no lifting, and the nice gloss remains.
BLB27
- First Name: Bruce
- Last Name: Brakke
Jim, I took your "I respectively suggest you review your prior post on this---" to mean I should not have asked for more comments. I wanted more comments so I asked for more.
lloyde
- First Name: Lloyde
- Last Name: Eckley
- * REQUIRED* Type and Year of Model Ts owned: 1923 Touring 1926 Roadster
Powder coating process was invented in 1945. It's not easy to remove if you should decide to restore the car to original, but it's your car so do what you like
If, after 27 replies, you need more help, to arrive at a decision, instead of starting a new thread and asking the same question, go back to the original thread and type in, “bump”. That will send your original question back to the top and allow members to see that it was a prior thread instead of a new post from someone else and see what was posted before, so as not to re-post suggestions that were posted on the original thread. This also helps future members who may be searching the forum for help on this subject by consolidating all the information in one thread, instead of splitting it up into several threads.
This happened in October when you could not get your gas cap off. On that thread, You received 16 responses. Then in the beginning of February you posted that you still could not get it off and received 45 responses. At the end of February, after 3 weeks, with no follow up on whether you got it off or not, we asked and received the answer from you that you had not even tried yet... Jim Patrick
So please tell us which comments you favor If its not to much to ask, perhaps you could summarize the Pro's & Con's for those who have contributed to your request less they be repeated again in this thread. Maybe you could filter out opinion's from facts as well.
Your first post mentioned you don't have a spray gun, or have sprayed with a gun. So rattle can or brush is the alternative. And now you suspect blast and powder coat of the frame, wheels, and axles is desired.
Powder coat is a good alternative, esp. if the sand blaster can coat too. Most powder coat facilities do sand blast, so for the money you are ahead.
Coat the frame after checking rivets and things that need correcting.
Coat the front axle, less the spindles, and protect the yoke threads, holes, and perch holes from coating.
Coating the rear housings is a bit more entailed, as protecting the outer bearing opening, grease retainer surfaces, perch and radius rod holes, and threaded brake shoe bolt hole, oiler holes, oil drain, and the inner opening of the pumpkins from any sand or coating is required. Cost will be much more for the prep. And you have to tell the blaster coater all this info too, they won't know.
Blasting and coating of the wire wheels is very much desired and easy for the powder coater to do.
To me, only the bare frame and wire wheels should be coated, all the other drive line components require a lot of protection and prep with knowledge of the works.
That is well stated, AGREE. Personally i would not P/C a frame for the some of the same reasons for rear end. Mounting holes need to be redrilled, grounding points must be reestablished, springs may not fit back in frame. If i could not paint it myself, i might go thru the hassles of powder coat or more likely rattle can it.
So as not to be overly redundant, I bumped his first thread up the top so everyone can review it and see what has already been posted on this subject. Jim Patrick
BLB27
- First Name: Bruce
- Last Name: Brakke
Jim, Thanks, now I understand what I should do in the future.
BLB27
- First Name: Bruce
- Last Name: Brakke
Thanks to all members for the comments. I have decided to brush paint frame, axles, wheels with Rust-Oleum primer and Rust-Oleum gloss black.
