Allen HCCT
Topic author - Posts: 224
- First Name: David
- Last Name: Wilson
- * REQUIRED* Type and Year of Model Ts owned: 1927 Canadian Touring
Allen HCCT
I have an old Allen HCCT. When I try to test a coil, I am only getting about 3 volts at 1.3 amps. Is this probably a symptom of weak magnets?
Re: Allen HCCT
If the coil is firing, it sounds like everything is fine.
- First Name: BOB
- Last Name: CASCISA
Re: Allen HCCT
Three Volts is typical for the Allen HCCT.
The voltmeter really doesn't provide any useful information as it it the current (Amps) that fire the coil.
I suspect that Allen included the voltmeter more as a marketing decision when they went from the large Jewell meter to the smaller Jewell ammeter.
Respectfully Submitted,
Be_Zero_Be
Be_Zero_Be
- First Name: Adam
- Last Name: Doleshal
Re: Allen HCCT
BE_ZERO_BE wrote: ↑Mon Apr 26, 2021 1:50 pmI suspect that Allen included the voltmeter more as a marketing decision when they went from the large Jewell meter to the smaller Jewell ammeter.[/b][/size]
Actually, The Allen HCCT has a provision for load testing the operation of the magneto in a running car via long test leads. That is the main reason it has the voltmeter.
- First Name: David
- Last Name: Wilson
Re: Allen HCCT
Thanks guys. I mostly just use the machine to entertain the kids with all the sparks but I do test the odd coil. Nice to know it is working as it should.
- First Name: BOB
Re: Allen HCCT
The magneto test as described in the Ford HCCT manual says to connect the car magneto to the HCCT test stand and run the engine at a moderate speed.
The Ammeter should register at least 0.8 Amps.
There is no criteria for a minimum voltage stated in the manual.
This test would be the same on all HCCTs with or without a voltmeter.
The John Regan test does call for a voltage measurement with a specific current load connected to the magneto.
Be_Zero_Be
Be_Zero_Be
