LED Bulb replacement for acetylene headlights
bdtutton
First Name: Bryan
Last Name: Tutton
* REQUIRED* Type and Year of Model Ts owned: 1914 Model T
Post by bdtutton » Fri Apr 30, 2021 3:36 pm
I would like to convert my acetylene headlights on my Model T to LED headlights. I found some nice halogen bulbs that mount directly onto your burner base at Langs. https://www.modeltford.com/item/BL-H.aspx Unfortunately, I don't have enough power to drive the halogen lights so I am looking for the equivalent option that uses LED bulbs. Several people have commented about LED replacement bulbs for gas headlights, but I can not find them. Does anyone know where I can buy some???
dmdeaton
First Name: Danny
Last Name: Deaton
Re: LED Bulb replacement for acetylene headlights
Post by dmdeaton » Fri Apr 30, 2021 6:06 pm
Someone will chime in as I cannot remember who. Someone on here was making them
Dan Haynes
Last Name: Haynes
Post by Dan Haynes » Fri Apr 30, 2021 6:28 pm
PDGx
First Name: Paul
Last Name: Grohsmeyer
* REQUIRED* Type and Year of Model Ts owned: ‘17 TT Holmes Wrecker
Post by PDGx » Fri Apr 30, 2021 8:16 pm
I’m using these from Snyder’s on my Mack.
PN: T-6602-LED
Snyder’s T-6602-LED
Snyder’s T-6602-LED
https://mtfca.com/phpBB3/viewtopic.php? ... 69#p136869
They are pretty decent, but 12v not 6.
If my short term memory gets any shorter, I won’t even have thought about what I’m going to forget.
22 Mack AC Tiltbed Wkr
30 A Rdstr PU
58 Mack B-61 Semi Tractor
PDGx
First Name: Paul
Post by PDGx » Mon May 03, 2021 6:09 pm
For what it’s worth -
Had one of these laying around and never used it on the T,
but thought I’d try to fire up one of these led conversion bulbs. 6v would not pass the start test, but these have no problem lighting them up.
Don’t know how much each lamp draws, but 3a might handle 2 if you must stay with a 6v system.
thom
First Name: Tommy
Last Name: Coffey
* REQUIRED* Type and Year of Model Ts owned: '21 Touring
Post by thom » Mon May 03, 2021 6:31 pm
Seems like such a shame to do the conversion, but I guess I understand wanting brighter lights. :(
Novice
First Name: Jim
Last Name: Davis
Post by Novice » Mon May 03, 2021 9:58 pm
How many lumens does a period model T acetylene headlight put out.
bdtutton
First Name: Bryan
Last Name: Tutton
Post by bdtutton » Tue May 04, 2021 12:11 am
I contacted Snyders today and they have T-6602-LED in stock....so I ordered some. I will be running a 12 volt system so these should work well. When I get the new LED lights I will run some tests and report my results.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Wed May 05, 2021 5:55 pm
Jim-
It depends on what size of burners you are using. They are rated in cubic feet of gas burned per hour.
Standard burners used on the Model T were .75
1 candlepower = 12.57 lumens
.50 burners put out 18 candlepower x 12.57 = 226 lumens
.75 burners put out 29 candlepower x 12.57 = 365 lumens
1.0 burners put out 45.6 candlepower x 12.57 = 572 lumens
How many lumens do those LED "burners" put out?
Just remember, if you electrify you acetylene lamps, you will looks a couple of points on the "cool factor".
-Keith
