Steve, See my 5-13 post under "Several Questions: About Hub Caps and Springs" . I asked you a question.
Thanks, Bruce BLB27
To Steve Jelf
Re: To Steve Jelf
OK, here you go: viewtopic.php?f=2&t=21080&p=162123#p162123
BLB27
Topic author - Posts: 893
- First Name: Bruce
- Last Name: Brakke
Re: To Steve Jelf
Thanks, Steve. One vendor has SLIP in a quart can. Another vendor has EZ-SLIDE in a quart but at half the price. I wonder if the material is the same. Do you know if a brush on material can be obtained in a smaller quantity? I would prefer to use a brush on, but maybe I will have to use an aerosol can.
Comments from anyone will be appreciated.
jiminbartow
- Last Name: Patrick
Re: To Steve Jelf
Go back to your original hub cap, spring, post and open the link I posted. I believe EZ-Slide is discussed. Jim Patrick
