mount front license plate
Topic author - Posts: 22
- First Name: Chris
- Last Name: Sheppard
- * REQUIRED* Type and Year of Model Ts owned: 1919 TT TRUCK
Does anyone have a good picture on how to mount a front license plate on a 1919 model ? Thanks for the help in advance.
CHRIS
CHRIS
Re: mount front license plate
This one fits the 1921-1927 spring clip. You could make something similar to use the 1920 and earlier spring clip, but it would need to have a jog up or down to miss the crank handle.
- First Name: Chris
Thanks, I'll have to make one with some drop to clear the crank
Chris
Chris
- First Name: Jim
- Last Name: Sims
The 19 uses a two piece mount. Part number 3664e in Langs catalogue.
The above bracket Steve has posted is through 1925 - the '26 - '27 bracket has a "drop" on it.
- First Name: Les
- Last Name: Schubert
However if your car is Canadian then the front license plate is located below the drivers side headlight. Several different versions depending on the year
- Last Name: Saylor
Here is the one Lang's sells[.
I have the Canadian version on our '19 Centerdoor due to the "anti-kick" device hanging in front !
- First Name: Bob
- Last Name: Middleton
- * REQUIRED* Type and Year of Model Ts owned: 18 roadster 1810 brand X
Have one that mounts to the top radiator neck
But just baing wire at the axle work best
- First Name: Erik
- Last Name: Johnson
The pair of license plate mounting brackets sold by the vendors are worthless.
They need to have dog-legs so the crank clears the license plate.
See the three photos that I posted in this thread - this is what is needed but good luck finding a pair.
http://www.mtfca.com/discus/messages/25 ... 1336307120
