Driveshaft- Pinion Gear puller
Retro54
First Name: Andrew
Last Name: Blaydon
Post by Retro54 » Tue Jun 01, 2021 12:52 pm
Embarking upon a rear axle assembly rebuild and this pinion gear is on here tight enough to give the cheapo harbor freight puller fits. Not wanting to ruin anything and being ready to man up for the right tool for the job, what gear puller would you recommend for this particular application? Thank you in advance for your suggestions.
Andy
Re: Driveshaft- Pinion Gear puller
Post by TRDxB2 » Tue Jun 01, 2021 1:44 pm
Some threads on the removal of the pinion gear and pinion bearing (the harder of the two)
Gear removal Jelf Method
Take off the nut, turn it around, and put it back on just far enough to be even with the end of the shaft. There should be a little space between the nut and the gear. Then do this: https://www.youtube.com/watch?v=Ta2NCzXcZnA
Bearing http://www.mtfca.com/discus/messages/33 ... 1387761711
Post by RajoRacer » Tue Jun 01, 2021 2:05 pm
Loosen the nut a bit and grab a large brass drift and a hand sledge & give the back of the gear a couple good whacks with OR a large brass hammer (2 lb.) works good !
Post by speedytinc » Tue Jun 01, 2021 2:10 pm
Neat trick, I will use it when the drift & hammer method is not enough. I have picked up some neat tricks here.
Retro54
First Name: Andrew
Last Name: Blaydon
Post by Retro54 » Thu Jun 03, 2021 6:57 am
TRD, thank you for the information! Dad looked it over and did the 'Jelf' method yesterday. Two strikes and it came right off! I appreciate Steve's common sense approach to things. You do not always need fancy tools, just common sense and mechanical advantage clearly can win the day.
Andy
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Thu Jun 03, 2021 10:44 am
In the worst case scenario, A cheap hydraulic press lifted with an engine hoist works great on the stubborn ones.
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Thu Jun 03, 2021 2:14 pm
I used Jeff Method either and work really well and is cheap. Jeff have a lot tips than I used. Thank you Jeff!
Super Mario Bross ;)
1911 Touring
1914 Speedster
