Crank gear removal
CTLeonard
Last Name: Leonard
Crank gear removal
Post by CTLeonard » Thu Jun 17, 2021 12:15 pm
Having a terrible time getting the crank gear off. Please tell me the trick . Thank you
Dropacent
Last Name: Morsher
Re: Crank gear removal
Post by Dropacent » Thu Jun 17, 2021 12:26 pm
Hot wrench is quickest if you aren’t going to try and reuse. Don’t cut all the way to the crank, though. Common sense
Last Name: House
Post by George House » Thu Jun 17, 2021 12:38 pm
Good grief !! Don’t, please don’t, use an oxy acetylene torch to CUT the crank gear off. I’m picturing slag and deformation of the crank. Use a 30 ton press and maybe oxy acetylene to WARM UP the crank gear. Press it off. If still unsure or unconfident, take it to an auto machine shop. They have the equipment necessary
Dropacent
Last Name: Morsher
Post by Dropacent » Thu Jun 17, 2021 1:14 pm
Did that make you faint, George? Mike is very experienced . It’s off in 30 seconds, and of course, I find common sense isn’t so common. So, I’ll add this. Don’t cut half way into the crank journal. Cover the exposed crank with something. You PROBABLY should take the crank out of the car AND the engine. Do not spray molten metal into your car interior that the doors are open on. OR, on your children watching closely. Don’t use the cutting torch next to a national forest that has high fire alert drought conditions. Put oil dry on gas puddles in your shop. Cover your gas can, and don’t leave it tipped on its side. DON’T CATCH YOUR HAIR ON FIRE, BUT IF YOU DO , HAVE AN EXTRA BEER HANDY! You can and should spray molten metal on the neighbors cat. I’m probably forgetting something. Duh
CTLeonard
Last Name: Leonard
Post by CTLeonard » Thu Jun 17, 2021 1:59 pm
Iam enjoying the entertainment. The motor is on a stand; with the pan off. The flame wrench- while appealing- maybe not so much. A cut off wheel? A person couldn't get in too much trouble. Could he?
Dropacent
Last Name: Morsher
Post by Dropacent » Thu Jun 17, 2021 2:25 pm
George maybe doesn’t realize up here in the rust belt the torch is sometimes your best friend. Also, time is money. Up in these parts we can cut a rusty small castle nut off without hurting anything but the nut. Even the threads survive.
The cutoff wheel is a good second choice, especially if crank is still in the block ;-) Go most the way and then use a cold chisel as a wedge to finish the dirty deed. All previous disclaimers apply, AND be sure to spray the sparks at the neighbors cat!
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Thu Jun 17, 2021 9:07 pm
Take the crank out and press the gear off. Usually doesn’t take much pressure. 1 to 2 tons maybe.
JEC
Last Name: Cox
* REQUIRED* Type and Year of Model Ts owned: 1915 Runabout, 1925 Pickup
Post by JEC » Thu Jun 17, 2021 10:13 pm
If its like a VW crankshaft you can remove the crankshaft stand it on end gear down and heat the gear while rotating the crank and the gear will fall off.
how's that for a short sentence?
Bill Coyle
First Name: Bill
Last Name: Coyle
* REQUIRED* Type and Year of Model Ts owned: 26 Roadster
Post by Bill Coyle » Thu Jun 17, 2021 10:18 pm
Just as Adam said remove the crank and use a press to remove the gear. Plus you will need the press to put a gear back on. Bill
Dropacent
Last Name: Morsher
Post by Dropacent » Thu Jun 17, 2021 11:24 pm
It still being in the block really changes my opinion and quick advice. Never thought that far ahead. I’ll crawl back in my hole now.
Last Name: House
Post by George House » Fri Jun 18, 2021 7:58 am
Yeah, Tim maybe didn’t realize the crank is still in the block so the heat necessary to foolishly cut the crank gear would totally turn #1 main to toast. Thank you Adam and Bill for confirming my initial advice.
Dropacent
Last Name: Morsher
Post by Dropacent » Fri Jun 18, 2021 9:56 am
George, not an excuse, but I assumed it was the cranks the OP offered a week back. They were loose cranks and he offered to sandblast them. Those would be perfect candidates for my removal method, with absolutely no damage done to the crank.
CTLeonard
Last Name: Leonard
Post by CTLeonard » Tue Jun 22, 2021 11:44 am
Finally success. I didn't know which was going to break first the puller the wrench the crank. Then SNAP!! Had to look to see what broke- just the gear giving up.that bugger was on there. Thanks for the comments!
Post by John kuehn » Tue Jun 22, 2021 2:31 pm
I have to ask! Did you use a cheater on the wrench? I have some 1 and 2” pipe in different lengths I use when I have to. Glad you got it done without breaking anything!
