Anyone have a lead for this window rubber?
Topic author - Posts: 90
- First Name: Eli
- Last Name: Cory
The rear side side windows on the 1924 Tudor are longer than the front windows and I only see the upper door window rubber for the fronts. Any leads on where I can get replacement rubber that is long enough?
- Last Name: Strange
Re: Anyone have a lead for this window rubber?
Check with the vendors, maybe they get it from the supplier on a roll and cut it to length. If they do have it on a roll, ask them to cut some to the length that you specify.
If its just the rubber, a piece can be added for the extra length. It done for O rings in industrial applications. A touch of super glue.
- First Name: Eli
- Last Name: Cory
Thanks guys. I emailed Lang’s and they didn’t carry just the rubber. Only the bracket with rubber installed. I’ll have to see who they get it from.
Go outside the box, Snyder's Model A section or do a search of automotive window weather seal.
- First Name: William
- Last Name: Vanderburg
Try Restoration Supply. I think they sell it by whe foot.
William L Vanderburg
1922 Center Door Sedan
