Things you find when taking car apart
Topic author - Posts: 444
- First Name: Dean
- Last Name: Brevit
Thought this was cool, mostly clear ink/paint stamp on inside. Also on the wood behind rear seat are chalk/wax pencil 19 and wavy line.
- First Name: William
- Last Name: May
Re: Things you find when taking car apart
Very interesting!
Where was this part located? Is this an original Ford part? I wasn't aware that Ford had a factory in Portsmouth, NH. Or am I assuming the wrong place?
Was this off a contract body such as a Boudette?
- First Name: Dean
- Last Name: Brevit
It's an original Ford part, it's a rear seat pillar or door hinge support off a 1923 touring body, I think it is Portsmouth, Ohio.
Were there any steel companies in the that town? Maybe that was the mill that rolled the steel supplied to Ford, not the ones that stamped it.
- Last Name: May
Yes, I would think there were steel mills everywhere in Ohio.
- First Name: Gordon
- Last Name: Clayton
- * REQUIRED* Type and Year of Model Ts owned: 27 TT
I found an old cotton work glove behind the ignition switch in my 27 TT. It appears that the old wires were shorting out
against the dash so the quick fix looked like it had lasted for years.
