which socket main bearing cap
Emeraude
Last Name: Loranger
* REQUIRED* Type and Year of Model Ts owned: 1921 touring
Post by Emeraude » Wed Jun 30, 2021 11:52 am
I am in the process of checking for a knock in my 21 touringI checking both the rods and main I see that the main crank bolts are a square bolt. My question is what is the safest socket to use so as not to strip the head of the bolt> All I have now is a 12 point.
Re: which socket main bearing cap
Post by speedytinc » Wed Jun 30, 2021 11:59 am
12 points are no good.
8 points are available(ebay) Square would be best. Original old service tools for this were square. Have not seen modern sockets in square.
Emeraude
Last Name: Loranger
Post by Emeraude » Wed Jun 30, 2021 12:20 pm
How about a 6 point impact socket?
Post by speedytinc » Wed Jun 30, 2021 12:34 pm
Hell no. 6 point on a square bolt? No. Get an 8 point. (Double square)
Post by Mark Gregush » Wed Jun 30, 2021 12:35 pm
its square, 6 point would not work. Needs to be original square or 9/16 8 point.
BobShirleyAtlantaTx
First Name: Bob
Last Name: Shirley
Post by BobShirleyAtlantaTx » Wed Jun 30, 2021 1:08 pm
. This is a Snap-on, probably easy to find on line or in your area.
TFan
First Name: Jim
Last Name: Riedy
Post by TFan » Wed Jun 30, 2021 3:38 pm
Here you go, the socket is a Wright 4fs18 and the wrench is a Mossberg 622 more than likely a copy of a Ford tool. Jim
Hudson29
First Name: Paul
Last Name: O'Neil
Post by Hudson29 » Wed Jun 30, 2021 7:09 pm
Would a regular open end wrench do the job?
paul
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Wed Jun 30, 2021 7:50 pm
Post by Scott_Conger » Wed Jun 30, 2021 8:54 pm
Do not be fooled into believing the way to release the center main is via the bolt heads. If you look carefully at them, that isn't a drip of oil hanging from a corner, but a "bump" indicating the direction of the cotter pin hole between the cylinders...the bump goes inward or outward...so that you have straight-on access to install cotterpins on the nuts.
the tightening is done on the nuts...you have but to hold the bolt steady with a wrench...not torque or untorque it.
All that said, let's hope you don't have a worn center main...if you do and are tempted to tighten it, you will elevate the risk of breaking the crank shaft in the future. They are notorious for wearing out as the 4th main wears out and allows the transmission to sag...this bows the crank up in the middle.
A center main knock can be all but eliminated by reving the engine sufficiently to stay running while you short out #2 and 3 cylinders...the knock will either disappear or be dramatically reduced. If this is the case, then it is indeed worn and you have some work ahead of you and it is not to just remove a few shims.
