What size allen wrench to drain differential?
Last Name: Hjortnaes
Post by DHort » Tue Jul 06, 2021 9:50 am
My friend needs to check his differential. I did not realize that a 27 needs an allen wrench to open the drain on his car. Can you tell me what size wrench I need? ........If it has been a long time and it does not want to loosen up, what is the best way to get that loose? I do not know if I want to heat that area or if I should just try an extension (pipe) on the wrench.
Re: What size allen wrench to drain differential?
Post by RajoRacer » Tue Jul 06, 2021 10:16 am
Shouldn't be an allen - isn't it square ? Should just take a 3/8" ratchet.
Post by Mark Gregush » Tue Jul 06, 2021 10:19 am
Should be a square hole, not allen wrench, unless someone has installed a different plug. 3/8" socket wrench should work if square hole.
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Tue Jul 06, 2021 10:34 am
The later Ford script adjustable wrenches have a square boss on the end of the handle for use with the Model T and Model A differential plug.
Post by Mark Gregush » Tue Jul 06, 2021 10:36 am
Removed by author
John Codman
Last Name: Codman
Post by John Codman » Tue Jul 06, 2021 10:50 am
Mine may have once been 3/8" square, but it's more like 7/16" now.
old_charley
First Name: Bryan
Last Name: Ostergren
* REQUIRED* Type and Year of Model Ts owned: 1914 cut-off touring/pickup: 1922 Touring car: 1921 TT Dump Truck
Post by old_charley » Tue Jul 06, 2021 10:56 am
Bung wrench. A handy addition to any toolbox!
Post by Rich Eagle » Tue Jul 06, 2021 11:43 am
Standard 1/2" NPT plugs are sold with a 3/8" hex size if that is what is in there.
Post by DHort » Tue Jul 06, 2021 3:57 pm
I will have to look closer. Just assumed it was a hole for an Allen wrench. Ratchet will be a lot easier. Thanks everyone.
Post by Scott_Conger » Tue Jul 06, 2021 4:10 pm
deleted due to really wrong information
