TiltLok Steering Wheel
Duckwing
First Name: Jim
Last Name: Wilson
Post by Duckwing » Wed Jul 07, 2021 4:03 pm
I have a TiltLok locking fatman steering wheel that I don't intend to keep but first wanted to make sure it works properly. It appears that when the key is rotated it shoves a pin in that prevents the center portion of the wheel hub from rotating. When the key is rotated the other way, the pin is retraced and the wheel spins on the hub thus the car isn't drivable. Is this how it works? As of yet, I can't get the wheel to spin on the center hub so maybe I don't understand.
1
1
2
2
If you look at this photo you can see the "hole" where the pin engages.
3
3
Two photos show the pin in both positions.
4
4
5
5
GG Gregory
First Name: GG
Last Name: Gregory
* REQUIRED* Type and Year of Model Ts owned: 27 Roadster
Re: TiltLok Steering Wheel
Post by GG Gregory » Wed Jul 07, 2021 7:10 pm
What type car does it fit ? I see it fits a splined shaft.
Duckwing
First Name: Jim
Last Name: Wilson
Post by Duckwing » Wed Jul 07, 2021 7:41 pm
I have no idea what it fits. I'm still trying to verify how it works. I've squirted WD-40 and PB-Blaster around the hub but have yet to get it to rotate (assuming that's what it should do).
Post by Scott_Conger » Wed Jul 07, 2021 8:19 pm
It is unlikely to ever rotate. It appears to be like any number of "T wheel locks where the pin engages a groove in the steering shaft to hold the wheel on, or in place and releasing the pin and lifting the wheel up (and re engaging the pin into another groove) locks the wheel off of the spline and allows it to ONLY spin and not steer the car. I do not know what this particular application fits but suspect that you are missing a lower portion which screwed onto the top of the steering column.
Dave Sullivan
First Name: David
Last Name: Sullivan
* REQUIRED* Type and Year of Model Ts owned: 1923
Post by Dave Sullivan » Wed Jul 07, 2021 9:17 pm
Might be early Model A.. Dave in Bellingham
Duckwing
First Name: Jim
Last Name: Wilson
Post by Duckwing » Wed Jul 07, 2021 11:00 pm
This is a photo from the bottom side. Does the hub slide up and down in the wheel vs rotating? I admit I’ve never seen a steering wheel like this so having trouble visualizing the action description provided.
Try
Try
Post by Scott_Conger » Thu Jul 08, 2021 10:28 am
Looking again more closely, there clearly is a snap-ring retaining ring in it and you may very well have figured out what it is supposed to do, and how. As for fixing it, loosening it, whatever, personally I'd leave that to the new owner.
Duckwing
First Name: Jim
Last Name: Wilson
Post by Duckwing » Thu Jul 08, 2021 3:56 pm
Think not messing with it is a good plan. My investigations in the past have not worked out well.
