1:1 timber plans?
Myxr6turbo
First Name: Shawn
Last Name: Barnard
* REQUIRED* Type and Year of Model Ts owned: 1926 coupe
1:1 timber plans?
Post by Myxr6turbo » Sat Jul 17, 2021 2:44 am
Afternoon everyone,
Are there any 1:1 timber plans for a 1926 T coupe that can be purchased?
Thanks in advance,
Last Name: Humble
Board Member Since: 2006
Re: 1:1 timber plans?
Post by Humblej » Sat Jul 17, 2021 7:03 am
Not aware of any.
Last Name: Humble
Post by Humblej » Sat Jul 17, 2021 7:09 am
Not aware of any. I went to the Benson Ford Research Center in Dearborn Michigan and copied the factory drawings. Most of them were not 1:1, and some were very poor blueprints that didnt copy well. The research center has a printing service but they will be reduced in size and a bit pricy considering there are about 8 or 10 drawings of the individual parts and a drawing of the assembly.
Kerry
Last Name: van Ekeren
Post by Kerry » Sat Jul 17, 2021 7:19 am
Shawn, is your T a USA import? as far as I know they are mostly steel, wood frame seat and a wood frame on the top. The top measurements for the top frame can be found with a google search of the MTFCA.
Post by Allan » Sat Jul 17, 2021 9:29 pm
Shawn, an Australian built 26-7 coupe may be vastly different in construction to a US built car. Frank indicated that US cars have way more steel in their construction, compared with Australian built cars which still have a full timber base. If yours is a RHD Australian built car it would be advisable to find someone with a similar car and go from there.
Hope this helps.
Myxr6turbo
First Name: Shawn
Last Name: Barnard
Post by Myxr6turbo » Sun Jul 18, 2021 6:07 pm
Thanks everyone,
This was an imported US car. I'll see if I can find the dimension in the search.
Thanks again,
ChrisB
First Name: Chris
Last Name: Brancaccio
Post by ChrisB » Sun Jul 18, 2021 6:23 pm
Chris Brancaccio
MTFCA Webmaster
MTFCA Forum Admin
Myxr6turbo
First Name: Shawn
Last Name: Barnard
Post by Myxr6turbo » Sun Jul 18, 2021 6:25 pm
Is this the link? Will this be the same as the 1926 Coupe soft top?
http://www.mtfca.com/discus/messages/41 ... 1395101672
