Cooling Cap.
Topic author - Posts: 133
- Last Name: Davis
- * REQUIRED* Type and Year of Model Ts owned: 1926 coupe
Cooling Cap.
What is the cooling capacity for a 26 T? Thanks
Re: Cooling Cap.
My 1925 which has the same size radiator, 3 row, takes a little over 2 gallons. You only need to fill to just under the bottom of the script on the radiator shell, or about an inch over the core. Any more than that will just get spit out.
Re: Cooling Cap.
I have 2-26's. I buy one gallon of the green anti-freeze and pour it in, then top it off with distilled water. Usually takes just over a gallon of water. I live in Southern California so it very seldom gets below freezing here. You might need a stronger amount of anti-freeze if it gets colder where you live.
