Name this tool
FordFool
Topic author - Posts: 168
- First Name: Don
- Last Name: Kirtley
- * REQUIRED* Type and Year of Model Ts owned: 13 and 16 touring, 18 and 20 coup, 20 tudor
- Board Member Since: 2009
Name this tool
Marked Ford 15 Z 4016. I can’t find it in the Big book. I’ll try to load a pic. I’ll have to figure out how to post a photo. It’s a puller for something. Any help?? Don
- First Name: Henry
- Last Name: Lee
Re: Name this tool
Very rare and hard to find I can tell from the photo's because it is invisible.
Hank
Hank
- First Name: Dallas
- Last Name: Landers
Re: Name this tool
Im gonna name it Greg.
Re: Name this tool
Not all "Z" tools are Model T. Model A, Fordson, and think Lincoln used "Z" tool numbers.
Re: Name this tool
Crankshaft sprocket puller, later than T, found in listings on Ford tool collectors website.
Re: Name this tool
You can add the pictures to your original entry by selecting the PENCIL ICON or by selecting POST REPLY at the bottom of the discussions
OR
THEN select the ATTACHMENTS tab to open acces to Files
Now select the ADD FILES button to get to your saved data.
once you have selected the file you want click on OPEN in the bottom right of that window and it will be added to the discussion -
continue the cycle of ADD FILES - select file - OPEN if you have more to do.
You can the PREVIEW your entries prior to SUBMIT button
There are ways to control the sequence of the added files. AND there are limits to size etc but that's lesson 2
John Heaman
- Last Name: Heaman
- * REQUIRED* Type and Year of Model Ts owned: Canadian 1912 Ford Model T Touring
Re: Name this tool
I have the same tool somewhere. I haven't been able to locate it lately!
I’m reading a book about anti-gravity. I just can’t put it down.
John E. Guitar
- Last Name: Guitar
- Board Member Since: 2012
John Heaman
- Last Name: Heaman
Re: Name this tool
It does say, 'not often seen!'
Re: Name this tool
If this tool came out a little later after T’s were in production what did the Ford dealers use to remove the gear so they could replace it. Wondering if it should have been called crankshaft gear puller or am I missing something. Or?
FordFool
- First Name: Don
Re: Name this tool
Thanks Frank and John. A friend gave me some Ford Z tools last week I could find the others in the book but not this one. Thanks again. Don
