1915 model T
Edy
Topic author - Posts: 33
- First Name: Ralph
- Last Name: Burrow
- * REQUIRED* Type and Year of Model Ts owned: 1915 model t...1926 T touring
1915 model T
New member here...just wanted to introduce myself and ask my first question...I recently bought my 1915 model T and I am ready to install the 6 volt battery and was wondering are the model T's positive ground or negative ground... I do have a 1919 engine in it with an electric starter but I just want to hook it up right so I don't mess anything up... thank you in advance as I have been doing a lot of reading here on the forum and really enjoy learning from what appears to be some very intelligent and knowledgeable people ... my T has been fully restored and has been sitting in a garage for the last 10 years and I can't hardly wait to here it finally running again...again thank you in advance...R E Burrow..Chugiak Alaska
ChrisB
- First Name: Chris
- Last Name: Brancaccio
- * REQUIRED* Type and Year of Model Ts owned: 1909 Roadster 1915 Coupelet 1923 Coupe 1926 Touring
Re: 1915 model T
Negative ground.
Make sure to clean all connections really good.
With all connections clean 6 volts will work well.
Chris
Chris
Chris Brancaccio
MTFCA Webmaster
MTFCA Forum Admin
MTFCA Webmaster
MTFCA Forum Admin
Re: 1915 model T
I have a good Model T friend in Eagle River - perhaps I can get you guys together ?
Re: 1915 model T
Be sure battery cables are the large 6V type. 0 gauge. NOT the skinny 12V cables 6 gauge.
Edy
- First Name: Ralph
- Last Name: Burrow
Re: 1915 model T
speedytinc wrote: ↑Fri Jul 23, 2021 10:00 pmBe sure battery cables are the large 6V type. 0 gauge. NOT the skinny 12V cables 6 gauge.
Thank you RajoRacer that would be awesome
Edy
- First Name: Ralph
- Last Name: Burrow
Re: 1915 model T
Thank you ChrisB.... I was thinking that it was but the old battery that was in it was not connected but it was sitting with the positive post by the ground wire so that's why I wanted to ask and make sure
Edy
- First Name: Ralph
- Last Name: Burrow
Re: 1915 model T
Yes that I had already checked and they are... thank youspeedytinc wrote: ↑Fri Jul 23, 2021 10:00 pmBe sure battery cables are the large 6V type. 0 gauge. NOT the skinny 12V cables 6 gauge.
Re: 1915 model T
A 1915 did not have a battery, box, or wiring for one originally. So anything would be something someone added. Often, people used the standard 1919 and later factory battery carrier. Sometimes they used era type after-market battery or tool boxes on a running board. Other people would scavenge up heaven-only-knows what themselves. Sometimes under a seat, or in a runabout's turtle deck. Almost anything is possible. Negative ground is preferred, but some people did wire model Ts backwards. There is a silly (read as stupid?) reason for that.
Re: 1915 model T
An Optima 6 volt battery can be laid on its side under the back seat. It just needs to be held down and have its terminals isolated from any other 'stuff' you might carry there. Otherwise the suggestions Wayne made are valid, but these involve drilling holes in the frame/splash panels which some would frown upon, me included. I did mount the battery in a tin box on the running board of my wide body D and F roadster, but that was how it was done originally on that car, so i was not fussed about drilling holes in the splash shield.
Edy
- First Name: Ralph
- Last Name: Burrow
Re: 1915 model T
Yes my engine is from a 1919 and the battery carrierWayne Sheldon wrote: ↑Fri Jul 23, 2021 10:24 pmA 1915 did not have a battery, box, or wiring for one originally. So anything would be something someone added. Often, people used the standard 1919 and later factory battery carrier. Sometimes they used era type after-market battery or tool boxes on a running board. Other people would scavenge up heaven-only-knows what themselves. Sometimes under a seat, or in a runabout's turtle deck. Almost anything is possible. Negative ground is preferred, but some people did wire model Ts backwards. There is a silly (read as stupid?) reason for that.
Edy
- First Name: Ralph
- Last Name: Burrow
Re: 1915 model T
Thank you AllanAllan wrote: ↑Sat Jul 24, 2021 1:21 amAn Optima 6 volt battery can be laid on its side under the back seat. It just needs to be held down and have its terminals isolated from any other 'stuff' you might carry there. Otherwise the suggestions Wayne made are valid, but these involve drilling holes in the frame/splash panels which some would frown upon, me included. I did mount the battery in a tin box on the running board of my wide body D and F roadster, but that was how it was done originally on that car, so i was not fussed about drilling holes in the splash shield.
Re: 1915 model T
If your car is a real 1915, you don't need any of that stuff listed above! Buy yourself a small 12 volt battery, about the size of a Model T coil. All you need is some 18 gauge wire for the positive and negative connections. That's it.
Re: 1915 model T
I agree with O.S. on my 15 touring I had one under the front seat and it worked fine.
Re: 1915 model T
I think some may have missed the part about this being a 1919 engine with starter.
ewdysar
- First Name: Eric
- Last Name: D
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Speedster #32, 1916 Touring, 1927 Runabout
Re: 1915 model T
When I recovered my Father’s very-not-original “16” touring after 25+ years of storage, it still had his 6v dry cell lantern battery (the square one with the coiled spring terminals) sitting under the driver’s seat at the end of the gas tank, wired up to the battery side of the coil box. Used only for starting, he said that it would last for years and 1000’s of touring miles. Replacements were available at any drug store or supermarket. Apparently, this was a pretty common solution for the active Model T Club members with non-starter cars in the early 1960’s (before the MTFCA was formed).Original Smith wrote: ↑Sun Jul 25, 2021 11:22 amIf your car is a real 1915, you don't need any of that stuff listed above! Buy yourself a small 12 volt battery, about the size of a Model T coil. All you need is some 18 gauge wire for the positive and negative connections. That's it.
Keep crankin’
Eric
Edy
- First Name: Ralph
- Last Name: Burrow
Re: 1915 model T
Thank you SteveSteve Jelf wrote: ↑Sun Jul 25, 2021 12:35 pmI think some may have missed the part about this being a 1919 engine with starter.![]()
Re: 1915 model T
One other thing to check. The polarity of the cutout on the generator. A Model A is wired with a positive ground and the cutout looks just like a T cutout. If the cutout is backward you will burn out the generator. The cutout should only allow the current to flow from the generator to the battery, but not from the battery to the generator, so if your cutout is correct with the engine not running, you should have voltage on the side of the cutout where the wire is connected, but no voltage on the side that is connected to the generator, then when the engine is running, you will have voltage on both sides. You can check this with a light bulb between the contact and ground. On the side toward the battery the light will light up but on the side toward the generator it will not light until the engine is running.
Re: 1915 model T
Edy
- First Name: Ralph
- Last Name: Burrow
Re: 1915 model T
Thank you Norm I will definitely check thatNorman Kling wrote: ↑Sun Jul 25, 2021 3:24 pmOne other thing to check. The polarity of the cutout on the generator. A Model A is wired with a positive ground and the cutout looks just like a T cutout. If the cutout is backward you will burn out the generator. The cutout should only allow the current to flow from the generator to the battery, but not from the battery to the generator, so if your cutout is correct with the engine not running, you should have voltage on the side of the cutout where the wire is connected, but no voltage on the side that is connected to the generator, then when the engine is running, you will have voltage on both sides. You can check this with a light bulb between the contact and ground. On the side toward the battery the light will light up but on the side toward the generator it will not light until the engine is running.
Re: 1915 model T
Ha ha! Brain flatulence again!!Steve Jelf wrote: ↑Sun Jul 25, 2021 12:35 pmI think some may have missed the part about this being a 1919 engine with starter.![]()
I DID see that and promptly forgot. Nothing new there.
Edy
- First Name: Ralph
- Last Name: Burrow
Re: 1915 model T
You mean I'm not the only one that has that brain flatulence problem???? Believe me it's not the heat.... 43 years in AlaskaTWrenn wrote: ↑Sun Jul 25, 2021 4:43 pmHa ha! Brain flatulence again!!Steve Jelf wrote: ↑Sun Jul 25, 2021 12:35 pmI think some may have missed the part about this being a 1919 engine with starter.![]()
or I could blame it on being out in the heat too much!
I DID see that and promptly forgot. Nothing new there.![]()
Re: 1915 model T
Ralph....LMAO!!!
Philip Lawrence
- First Name: Philip
- Last Name: Lawrence
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1917 Runabout, 1919 Touring
- Board Member Since: 2014
Re: 1915 model T
Please post photos of your model T. It could be a pre-dated 1919 made to look like a 1915. This has been very common thing to do over the years. That by the way doesn't make it right. The 1915 Ford has been the most faked model year.
This is why model T's from 1916, 17, 18, (especially are so rare today). 1919 and 1920 year models have also been converted into 1915's but are more common today because of the larger number of them being produced as opposed to the earlier models.
For those that know the differences these modifications really stand out big time. I don't really think the difference in value between a 1915 and a 1919 is much. Post some detailed photos so members on the forum can determine the correct year of your car. I would suggest that if it is a later year model T that you correct any modifications done to it to make it appear like a 1915. Or if none of this matters to you at all then you can just leave things as they are. Good luck and Happy New Year!
Re: 1915 model T
I'll bet that some time in the last 5 years, he got something figured out
How/why do these old threads get dredged up?
Tim Moore
- First Name: TIMOTHY
- Last Name: MOORE
- * REQUIRED* Type and Year of Model Ts owned: As many as can fit in the buildings, need to add on again.
Re: 1915 model T
Mystery to me also, seems quite random and strange.
Re: 1915 model T
Do you want to keep it all 1915?
