Moxie26 wrote: ↑Sat Jul 24, 2021 10:29 am
Paddy.…..  how did you make out setting gap on your new plugs ... Engine start easier, better performance..?
I was a little skittish about bending those electrodes.  Out of the box they were gapped about .010.  I didn't want to do too much bending back and forth, so anything between .025 and .030 I called good.
While I'm not disappointed, I haven't noticed any better performance over the three dollar Motorcraft's that are now in the drawer.  I think.
It IS starting much easier, but I attributed that to a fully charged battery and properly adjusted generator, which I did at the same time.
And after reading one of Scott Conger's posts on another thread I figured out that I was winding it up too much in low gear, like you would a Volkswagen Beetle.  Shifting to high at a lower road speed has made the car run exponentially better.  At least it seems like it.
So it seems I introduced too many variables to be able to confidently state that the Champion X's are making it run better.  It's not running any worse, and it looks a helluva lot better!
