Which Way Does the Rear Axle Key Go ???
Topic author - Posts: 5602
Over on the Ruckstell breakdown illustrations thread recently provided by Mr. Vowell, there seems to be a question regarding the proper or correct orientation of the rear axle key being installed onto the axle - I install with the taper pointing down and towards the bearing - there is an "artist's" rendition in the T Bible which appears to be the orientation shown & Jim Bartsch also follows. Does anyone else having definitive proof or documentation of the correct installation ?
Re: Which Way Does the Rear Axle Key Go ???
I install with the taper pointing down and towards the bearing...
Me too. But after having to cut a notch in the outer end to pry one out when it was in the slot really tight, I grind a little chamfer on the bottom of the outside end so I can drive a screwdriver under it to get it out.
This didn't work.
A little pry bar made from a piece of key stock finally got it loose.
I've always grabbed the key with a dykes (side cutter) - works 95% of the time.
sweet23
- First Name: Darryl
- Last Name: Bobzin
- * REQUIRED* Type and Year of Model Ts owned: 2, '25 T Runabouts, '14 Touring
Some of the aftermarket keys are long. Be sure to check that it is not getting into your outer seal.
The axle key slot tapers up @ the seal side. That ground radius in the key fits that. Later ford keys are shorter & dont have a ground radius in the key.RajoRacer wrote: ↑Sun Aug 01, 2021 12:28 pmOver on the Ruckstell breakdown illustrations thread recently provided by Mr. Vowell, there seems to be a question regarding the proper or correct orientation of the rear axle key being installed onto the axle - I install with the taper pointing down and towards the bearing - there is an "artist's" rendition in the T Bible which appears to be the orientation shown & Jim Bartsch also follows. Does anyone else having definitive proof or documentation of the correct installation ?
The short key works fine as is if it doesnt move inward.
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Just a trick to keep a well fitting but loose key from moving-1) upset a slight "ding" on one edge of the key to hold it in place in the axle. 2) a drop of super glue will hold the key in position also.
I lucked out many years ago, and obtained several NOS Ford script keys.
Ford Service , paragraph 639.
Original Ford axle keys, the taper goes down and into the taper end of the axle keyway, toward the rear axle housing.
That way the entire length of the axle key surface is within the hub.
Square end of the axle key enters the hub keyway.
Don't forget to place a well greased new wheel hub felt, {B} into the groove of the inside of the rear hub, helps prevent axle lube leaks and acts as a nice bushing against the retainer cup over the ends of the Hyatt bearing.
Thank you Dan - that is quite definitive !
