Accessory steel wheel
Zed1_inKC
Topic author - Posts: 11
- First Name: Gary
- Last Name: Blakely
- * REQUIRED* Type and Year of Model Ts owned: 1923 Touring, 1927 Tudor
Picked this up at Turners Auto Wrecking in Fresno. Before posting here, I did some searches for accessory Model T wheels. Found this post;
http://www.mtfca.com/discus/messages/17 ... 1323720059
This my first attempt to post on the new forum and also my first attempt to post pics. If I did it right, the first pic is one I copied from the link above.
The second is the wheel I found at the wrecking yard. The first one (from the link above) appears to use the stock 21 inch Model T rim. The one I found uses an 18 inch rim. Anybody know anything about these?
I’m looking at the preview now and the pics are reversed. The wheel I found is the one with some remnants of yellow paint and has the rim and tire with it. The other one is from the link to a previous discussion. I has no paint, nor a rim or tire.
46woodduck
- First Name: Thomas
- Last Name: Petry
Re: Accessory steel wheel
Interesting wheels, perhaps aftermarket.
John E. Guitar
- Last Name: Guitar
- Board Member Since: 2012
That's very cool.
Would you be able to weigh it?
Gary
That wheel was probably from the same mfg., only a version in de-mountable type.
This company made clincher style metal pressed with spoke type shapes too.
Zed1_inKC
- First Name: Gary
Thanks for the responses. What I find most remarkable is that the wheel I found used an 18 inch rim/tire. It is surprising to me that long after the Model T was taken out of production someone makes an accessory wheel that uses a tire size Ford would not use until 1932. What do you think?
John Warren
- Last Name: Warren
It would make great TT wheels.
- First Name: Henry
- Last Name: Lee
I saw a pair of these on the front of a Doodle Bug Tractor and the man that own it told me they were in demand back in the day because they drilled holes in them, laid them flat, installing nails bending them over, hog wire or chicken wire then pour concrete for weighted wheels during the Great Depression. Yours are the first for me with no concrete.
Thanks for sharing!
All the Best,
Thanks for sharing!
All the Best,
Zed1_inKC
- First Name: Gary
John Guitar,
I was able to weigh the wheel this morning. It weighs around 30 lbs. Keep in mind it includes the rear hub and 26-27 drum, but not the demountable 18 inch rim. In fact, it was probably only because the wheel was still attached to a T rear axle which I recognized, that I was able to surmise it was an accessory wheel for a Model T. Had it been lying on the ground I likely would not have noticed it was for a T since I’ve never seen one before. Until I can further disassemble the wheel from from the hub I won’t be sure if the hub is also an accessory and not just a standard wood wheel hub. I’m still curious about the use of an 18 inch tire with this wheel. It sure seems as though the intent was for something other than an otherwise stock T road car.
John E. Guitar
- Last Name: Guitar
Thank you Gary.
