1921 Center Door Gas Tank Mounting Question
AZVT
First Name: Jamie
Last Name: Longtin
* REQUIRED* Type and Year of Model Ts owned: 1927 Touring & 1919 & 1927 Dr's Coupe
Post by AZVT » Thu Aug 19, 2021 8:43 pm
I need some help figuring out how to mount the gas tank located under the driver's seat on my '21 Center Door. Does it sit on top of the floorboards and be held in place by the driver's seat and if so how is it bonded to the car's frame? I can't find any photos online or an explanation on how it is attached? If you can post some pictures that would be a great help! Thanks...
Jamie
FordFool
First Name: Don
Last Name: Kirtley
* REQUIRED* Type and Year of Model Ts owned: 13 and 16 touring, 18 and 20 coup, 20 tudor
Board Member Since: 2009
Re: 1921 Center Door Gas Tank Mounting Question
Post by FordFool » Thu Aug 19, 2021 8:57 pm
In my 20 it’s held in place by the seat. Pretty tight fit no room for hold down brackets.
mtntee20
First Name: Terry & Sharon
Last Name: Miller
Post by mtntee20 » Fri Aug 20, 2021 5:32 am
+1 Held in place by the seat frame. When I removed the driver's seat in ours, it all came out as one piece. Haven't taken it apart yet to see how it's secured in the seat frame.
AZVT
First Name: Jamie
Last Name: Longtin
Post by AZVT » Fri Aug 20, 2021 8:06 am
How (or is it) bonded metallically to the frame or is it isolated? Seems like a risk of static discharge without an electrical/mechanical bond to the car's frame.
Jamie
Last Name: House
Post by George House » Fri Aug 20, 2021 11:42 am
Jamie, it’s not attached to the frame at all. As previously mentioned, it’s captured inside the drivers seat.
Post by TXGOAT2 » Fri Aug 20, 2021 11:44 am
Pssst! DON'T TELL RALPH!
Post by Mark Gregush » Fri Aug 20, 2021 1:15 pm
It would be grounded through the supply pipe that feeds the carb. If worried about grounding and using rubber connections, you could mount a ground between the seat frame and floor mounting screws, then running it to the frame somewhere.
You are not just sitting on the gas tank directly, there is a carpeted surround that mounts to the floor that the gas tank sits in. Do a search of "mtfca.com; center door gas tank".
