Timesaver
Topic author - Posts: 3960
Timesaver
Has anyone used the 80 grit Timesaver? I've used the 60 grit, which works fast, and the 100 grit which takes awhile. It seems to me the 80 grit would be the way to go, but haven't used it.
RGould1910
- Last Name: Gould
Re: Timesaver
Like you say it all works. Depends on the application.. The lower the grit the harder it is to turn. When doing mains or rods, I use medium grit and don't bolt things down too tight at first. Follow the directions and be sure to add oil frequently. A couple applications doesn't hurt. Smiley face.
