#1 & #2 main bearing cap bolt lengths
John Haynes
Last Name: Haynes
* REQUIRED* Type and Year of Model Ts owned: 1910,1911,1912,1913.1914
Post by John Haynes » Thu Sep 09, 2021 6:56 pm
I have been cleaning a lot of main bearing cap bolts from motors which were disassembled and I discovered that there are two lengths of bolts for the #1 and #2 bearing caps. Some are 5 5/8 long and some are 6 1/8 long. I have a 24 block and it will take the long bolts. Can anyone tell me what year the change in the bolt lengths was made?
Kerry
Last Name: van Ekeren
Re: #1 & #2 main bearing cap bolt lengths
Post by Kerry » Thu Sep 09, 2021 7:07 pm
I'd have to say in doing many T engines from all years, I've never come across a 1/2" difference in main bolts.
Post by Mark Gregush » Thu Sep 09, 2021 7:33 pm
Could be Model A main bolts. The Model A and T main bolts look the same.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Thu Sep 09, 2021 8:42 pm
The shorter ones are Model A/B.
John Haynes
Last Name: Haynes
Post by John Haynes » Thu Sep 09, 2021 9:05 pm
Thank you Gentlemen!
Post by Mark Gregush » Thu Sep 09, 2021 9:59 pm
I would have to do some checking, but during Model A production, the caps went from cast to forged and got thinner. The early cast caps may have used the same bolts as the T. The forged type, the area where bolted to block was thinner so may have used a shorter bolt.
Dan McEachern
First Name: DAN
Post by Dan McEachern » Fri Sep 10, 2021 2:35 am
Mark- all Model A/B front and center caps are steel forgings and use the same length bolt. Early Model A rear caps were steel forgings as well. Later A and all B rear main caps are cast iron. The early A rear main cap uses a shorter bolt that the later cast rear main caps.
The result is there are three similar looking but different length T/A/B rear main bolts out there. Hope this clarifies things a bit.
Post by Mark Gregush » Fri Sep 10, 2021 10:01 am
Yes, thank you Dan.
