adding fuel pump
adding fuel pump
l am adding a fuel pump need to lower fuel pressure any suggestions
Re: adding fuel pump
Simple, add a pressure regulator set to 1-1.5 LBs. Suggest if you have questions, sign-up and ask your question on the general forum. This is not the section to ask car related questions. When you do sign-up and post, tell us why you think you need a fuel pump, because that will come up. Is this Ford Model T related or hot rod?
Another ghost! Tis almost the season!
Ma-ha-ha
