Cooling system capacity
Rob Patterson
Last Name: Patterson
* REQUIRED* Type and Year of Model Ts owned: '21 Canadian built Aust'n Bodied (Steenbohms) Touring & '15 Speedster
Board Member Since: 2003
Post by Rob Patterson » Thu Mar 21, 2019 5:43 pm
Can someone, anyone, give me an approximation of this cooling system capacity please.
Its a '25 block with a Waukesha Ricardo head and a 1915 Brassworks Radiator.
Thanks & Cheers,
Rob
"When everything seems to be going against you, remember that the airplane takes off against the wind, not with it." HENRY FORD
Matt in California
First Name: Matt
Last Name: G
* REQUIRED* Type and Year of Model Ts owned: 1926 Touring, 1926 Fordor Project, TT C-cab flatbed farm field find, TT dump truck project
Re: Cooling system capacity
Post by Matt in California » Thu Mar 21, 2019 11:22 pm
Rob,
I am not sure what units you would like your answer in. But I would imagine that that system would have the capacity to cool one Model T engine. :D :roll:
Matthew
ewdysar
First Name: Eric
Last Name: D
Post by ewdysar » Fri Mar 22, 2019 1:26 am
Hi Rob,
From the 1923 Ford Dealers’ Data Book:
Cooling system contains exactly 2 gallons 7-1/2 pints of water.
Radiator contains exactly 2 gallons of water.
Since you describe a combination of various parts, 3 gallons should be enough to fill your system from dry. I would hold back about a pint to see where the system settles after driving for a few miles and then add as needed to zero in on the proper operating level.
Keep crankin’
Eric
Rob Patterson
Post by Rob Patterson » Fri Mar 22, 2019 1:35 am
Thanks Eric,
I've now got it sorted.
Cheers,
Rob
