Backfiring going down hill
Dennis K Anderson
First Name: Dennis K
Last Name: Anderson
* REQUIRED* Type and Year of Model Ts owned: 1927 Mail truck
Board Member Since: 2010
Post by Dennis K Anderson » Mon Sep 27, 2021 8:19 pm
What makes a model t engine backfire going down hill. The throttle is all the way up. Is it carburetor or timing?
Dennis K Anderson
Maryville Tn
Re: Backfiring going down hill
Post by Scott_Conger » Mon Sep 27, 2021 9:07 pm
Running very lean under those conditions. My Austin Healey would do that too, when downshifting. Never done that in the T.
Don D
First Name: Don
Last Name: Demio
* REQUIRED* Type and Year of Model Ts owned: 1919 T
Post by Don D » Mon Sep 27, 2021 9:20 pm
Dennis,
I am not a mechanic just a parts changer. :-) If you are referring to that beautiful Postal Truck you built I think the issue may be a loose nut behind the wheel buddy. Seroiusly, call me, I have a spare rebuilt carb you can borrow to see if yours needs to be rebuilt.
May best to Ms. Connie,
Dom
Post by Norman Kling » Mon Sep 27, 2021 9:21 pm
If the spark is retarded going downhill, the spark will come late, causing some of the fuel to ignite in the manifold or muffler.
Bill Robinson
First Name: Bill
Last Name: Robinson
* REQUIRED* Type and Year of Model Ts owned: '21 Depot Hack, '25 Touring Car, '26 Roadster Pickup, '27 Tudor, & another '27 Tudor
Post by Bill Robinson » Mon Sep 27, 2021 9:24 pm
Dennis- I'll bet that you are not running a standard Model T muffler. I'm running a muffler for an 8N tractor on most of my T's and they all backfire going downhill, but only if the timing is retarded. They are tough mufflers- much tougher than the Ford take-apart mufflers that are destroyed by a backfire.
When my granddaughter was young we'd be on a tour and I'd make the car backfire and she be in the back seat yelling "do it again, Poppy!" :D
Cows on the roadside hate it. :lol:
Post by Jerry VanOoteghem » Mon Sep 27, 2021 11:17 pm
Describe what you mean by "backfire". Do you mean explosions in the muffler, or "popping back" out of the carburetor? Each has a different cause.
Dennis K Anderson
Last Name: Anderson
Post by Dennis K Anderson » Tue Sep 28, 2021 5:22 am
The backfiring is in the muffler. I am running one of those stainless steel mufflers. I don't think it will burst apart, but popping like that can't be too safe. Your commits are helpful and I will continue to chase this problem. Dom, I have been looking for that loose nut behind the wheel for a long time. Can't seem to find it. Thanks.
Dennis K Anderson
Maryville Tn
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Post by Charlie B in N.J. » Tue Sep 28, 2021 6:50 am
What Mr. Kling said.
