Generator problems
Jim Eubanks
First Name: Jim
Last Name: Eubanks
* REQUIRED* Type and Year of Model Ts owned: 1926 touring, 1927 cpe
Generator problems
Post by Jim Eubanks » Wed Sep 29, 2021 5:30 pm
T gen with fun products brush plate and regulator cutout. Gen motors when connected to pos lead and neg lead on case. Will not charge, Have moved the third brush back and forth, tightened it down and nothing. Even ran a jumper across the cutout, gen to bat side of the cutout and no charge. Any suggestions?
Re: Generator problems
Post by speedytinc » Wed Sep 29, 2021 5:39 pm
Is this a new install? have you polarized it? When running do you have any voltage from the generator output terminal with an analog meter? Battery voltage @ the regulator output side? Is the FP regulator voltage rating match your battery?
Post by Scott_Conger » Wed Sep 29, 2021 5:42 pm
Whatever is wrong with the generator (bad null, short, etc) is now compounded with a possibly destroyed VR. The VR should never be part of a troubleshooting exercise, as it WILL be damaged by jumpering.
Good luck with the troubleshooting and hopefully you still have an operational VR when you're done, but don't count on it.
Jim Eubanks
First Name: Jim
Last Name: Eubanks
Post by Jim Eubanks » Fri Oct 01, 2021 9:30 am
Sorry about the double post. I dropped the gen off at a local shop to see what they can do with it after I removed the reg which was a FP reg.
