Jack rabbit clutch question
RGould1910
Last Name: Gould
Post by RGould1910 » Fri Mar 22, 2019 9:05 pm
I discovered I have a number of Jack rabbit clutch discs but don't know if it is a full set. I have eight of them. Is this the right number for a 27 transmission, coupled of course with the right number of outer discs?
Jack Putnam, in Ohio
First Name: Jack
Last Name: Putnam
Re: Jack rabbit clutch question
Post by Jack Putnam, in Ohio » Fri Mar 22, 2019 9:11 pm
Nine are in a full deck!
Kerry
Last Name: van Ekeren
Post by Kerry » Sat Mar 23, 2019 12:30 am
Jack and turbo for what I can remember, are set up with the small disc and 8 is the right number, 10 to 11 big Ford discs, the watts used the fibre big discs and small Ford discs.
Post by Allan » Sat Mar 23, 2019 9:31 am
8 pr 9 will do. The important thing to remember is that the finished stack needs to be the same thickness as the standard Ford clutch pack. This may mean adding an extra Ford disc or two to make up the difference.
Hope this helps.
Allan from down nunder.
Post by Mark Gregush » Sat Mar 23, 2019 12:44 pm
RGould1910
Last Name: Gould
Post by RGould1910 » Sun Mar 24, 2019 10:00 am
Thanks for the input. Didn't know about instructions being available on line . Very helpful.
