I did it again…
mbowen
First Name: Miles
Last Name: Bowen
I did it again…
Post by mbowen » Sun Oct 03, 2021 6:45 pm
I bought my first T a bit over 3 months ago. I just made a handshake deal a few hours ago on a second one. Both the title and engine number say it’s a ‘24.
Some say the ideal number of T’s is three… 😁
Miles
1924 Touring “Bonnie”
1925 Express Wagon “Clyde”
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Re: I did it again…
Post by MichaelPawelek » Sun Oct 03, 2021 6:50 pm
“Double your pleasure, double your fun”!
Re: I did it again…
Post by Jerry VanOoteghem » Sun Oct 03, 2021 6:53 pm
Looks like a nice one! Congratulations!
Last Name: Hjortnaes
Re: I did it again…
Post by DHort » Sun Oct 03, 2021 7:33 pm
Depends on the garage space
mbowen
First Name: Miles
Last Name: Bowen
Re: I did it again…
Post by mbowen » Sun Oct 03, 2021 7:49 pm
Where in SE Michigan Jerry? I should be reachable via email if you don’t want to post publicly.
Miles
mbowen
First Name: Miles
Last Name: Bowen
Re: I did it again…
Post by mbowen » Sun Oct 03, 2021 7:55 pm
Plenty of room for two; the third might require some creativity. :lol:
Miles
Re: I did it again…
Post by Steve Jelf » Sun Oct 03, 2021 9:11 pm
It looks like the hinges say 1924 too. You're not too far off from Dearborn. Maybe you can drive a T to the OCF next year.
Re: I did it again…
Post by Norman Kling » Sun Oct 03, 2021 9:44 pm
Three is the ideal number. You can drive one while you work on the second and use the third for spare parts. However, I got all three running. So now I do some work to help others, but only work on mine if they break down. I built a large garage which will fit 4 cars. The door is 10' high so the T's will drive right in even with the top up.
JohnM
Last Name: Michaelree
Board Member Since: 2010
Re: I did it again…
Post by JohnM » Sun Oct 03, 2021 10:08 pm
Nice car! Hope it has a starter, there's no crank! :)
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Re: I did it again…
Post by MichaelPawelek » Sun Oct 03, 2021 10:18 pm
Are my eye’s lying or is that some type of honeycomb radiator?
JohnM
Re: I did it again…
Post by JohnM » Sun Oct 03, 2021 10:26 pm
Yes, it does look like it. My first T had one. Never had a problem with it.
Dennis Prince
Last Name: Prince
Re: I did it again…
Post by Dennis Prince » Sun Oct 03, 2021 11:35 pm
Be careful there is no 12 step program to get over old cars, once you get to 12 you just go to 13. Nice looking car, Have fun with it.
mbowen
First Name: Miles
Last Name: Bowen
Re: I did it again…
Post by mbowen » Mon Oct 04, 2021 12:23 am
Only about 46 miles by expressway. I need to work out Model T-friendly routes to both Greenfield Village and the Piquette plant.
Miles
mbowen
First Name: Miles
Last Name: Bowen
Re: I did it again…
Post by mbowen » Mon Oct 04, 2021 12:26 am
The lack of a crank was one of the first things I noticed about it. How big of a job is it to add one?
Miles
mbowen
First Name: Miles
Last Name: Bowen
Re: I did it again…
Post by mbowen » Mon Oct 04, 2021 12:33 am
That’s just aliasing in the digital photograph caused by lowering the resolution for posting to the board. It actually looks pretty much like the radiator on my ‘25 express wagon.
Miles
mbowen
First Name: Miles
Last Name: Bowen
Re: I did it again…
Post by mbowen » Mon Oct 04, 2021 12:37 am
:lol:
There’s a saying in the aviation world that the proper number of airplanes one should have is the current number plus one.
Miles
Re: I did it again…
Post by Jerry VanOoteghem » Mon Oct 04, 2021 12:42 pm
Hi Miles. I'm in Harrison Township.
Have a look at our chapter website, The Casual T's. We're normally a very active group, when viruses don't keep us inside...
http://casualts.org/
Re: I did it again…
Post by Norman Kling » Mon Oct 04, 2021 1:51 pm
The easiest way to add the crank would be to remove the radiator first. If the original pulley is the original type pressed steel, It can be done with difficulty with the radiator on. You first need to put in the ratchet which fits inside the front pulley and then put in the crank and line up the hole in the ratchet with the hole in the crank. There also is a spring which pushes the crank out when it is not being used.
Re: I did it again…
Post by speedytinc » Mon Oct 04, 2021 2:55 pm
ts not that tough if the pin is still in, holding the pulley in place as originally done. Its a bit tricky to R&R the crank ratchet cotter & pin. However, there is a real handy after market pin with a spring clip that makes it a breeze being reproduced.
Bruce Compton
First Name: Bruce
Last Name: Compton
* REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
Re: I did it again…
Post by Bruce Compton » Mon Oct 04, 2021 3:15 pm
Before you install the crank ratchet, grind about 3/16" off of the back of it so you don't have to remove the assembly to change the fan belt. The missing 3/16" allows the crank to be drawn farther back and away from the crankshaft pulley making it possible to get the belt out. The spring clip as previously mentioned is a big help too.
mbowen
First Name: Miles
Last Name: Bowen
Re: I did it again…
Post by mbowen » Tue Oct 05, 2021 10:42 am
I joined Casual T’s immediately upon buying my express wagon. I’ve asked to have someone come take a look at it’s engine while I have its head off, but no luck so far.
Miles
Re: I did it again…
Post by Jerry VanOoteghem » Sun Oct 10, 2021 7:59 pm
Miles,
I sent you an email...
mbowen
First Name: Miles
Last Name: Bowen
Re: I did it again…
Post by mbowen » Tue Oct 12, 2021 12:21 pm
Thanks for reaching out Jerry! My ‘24 Touring arrived this morning, and I’m picking up the head for my ‘25 Express Wagon from the machine shop later today. You’ll have lots to look over tomorrow.
Some say it only takes two to call yourself a collector…
Miles
