HCCT tear down question
Don ellis
Topic author - Posts: 386
- First Name: Don
- Last Name: Ellis
I’m starting the restoration of this tester and was wondering about how this pin is removed. I know I can drive it out but without a hole in the other side how do I drive it back in? It’s not like a crank pulley with a hole on both sides.
- Last Name: Humble
Re: HCCT tear down question
Pictures? Manufacturer of HCCT?
BE_ZERO_BE
- First Name: BOB
- Last Name: CASCISA
That looks like a Ford or early Fairbanks HCCT.
Here is an exploded view of your tester.
app.php/gallery/image/1557
Sorry, I can't offer any insight on how to get the pin out
Respectfully Submitted,
Be_Zero_Be
Be_Zero_Be
- Last Name: Humble
I would suggest removing the crank handle and pulling the shaft out the back side.
From the exploded view, no need to remove pin. work from the crank end to disassemble. If view is accurate, looks like a taper pin.
Weren't the motor driven ones later? After the shaft is pulled out, probley with the flywheel still attached, drill a hole in the pulley, so the pin could be driven out from the other side.
BE_ZERO_BE
- First Name: BOB
The original Ford 18-Z-245 HCCT had a pully.
Be_Zero_Be
Be_Zero_Be
George Mills
- Last Name: Mills
The bigger question is...
Is that a taper pin with a mushed down head to make sure the taper 'bit'...or...is it a rivet? View from the 6 o'clock position would help. I would tend to agree with others...take it apart from the other side, save that as a last disassemble task...
I'm no purist on things like that...lol. Get it out, drill for a shoulder bolt loctite it in place with a nut and washer...
Don ellis
- First Name: Don
- Last Name: Ellis
Good idea, I hadn’t thought about working it from the other end. It is a taper pin but no provision to remove it. from what I can tell it is a Ford.
AndyClary
- First Name: Andrew
- Last Name: Clary
I just checked my Ford HCCT. The pin is not tapered, it is about the same fit as a crank pulley pin. I tapped it in a little and then back the other way with a long thin punch. Once it was out about a half inch I just worked it out the rest of the way with a pair if diagonal cutters. That said, your unit looks a lot rougher than mine. Now to go put it back together so I don’t lose the pin.
Andy
Andy
