Differentials
jeffstag
Last Name: Versteeg
* REQUIRED* Type and Year of Model Ts owned: '27 TT, '25 TT, '23 Fordor, '23 Touring
Differentials
Post by jeffstag » Fri Oct 08, 2021 3:31 pm
What is the difference in these differentials ?
23 Touring
23 Fordor
25 TT
27 TT
Re: Differentials
Post by speedytinc » Fri Oct 08, 2021 3:35 pm
Flip em over. One probably has the long thru bolts (left?). The other studs?
jeffstag
Last Name: Versteeg
Re: Differentials
Post by jeffstag » Fri Oct 08, 2021 3:39 pm
Correct
23 Touring
23 Fordor
25 TT
27 TT
jeffstag
Last Name: Versteeg
Re: Differentials
Post by jeffstag » Fri Oct 08, 2021 3:40 pm
But what does that mean in terms of yeas used?
23 Touring
23 Fordor
25 TT
27 TT
Re: Differentials
Post by speedytinc » Fri Oct 08, 2021 3:43 pm
I prefer the security of the thru bolt style. If you use the stud type, the wire nuts together, no cotter pins.
Re: Differentials
Post by speedytinc » Fri Oct 08, 2021 3:45 pm
Left is later style. Dont know the year they changed off the top. A trip to McCally will be in order.
Last Name: Hjortnaes
Re: Differentials
Post by DHort » Fri Oct 08, 2021 4:05 pm
The one on the left has grooves cut in the top and the spider gear appears to be out of alignment.
jeffstag
Last Name: Versteeg
Re: Differentials
Post by jeffstag » Fri Oct 08, 2021 4:18 pm
I have several with those grooves. If we’re looking at the same thing those are supposed to be there. Here’s another one with the grooves
23 Touring
23 Fordor
25 TT
27 TT
jeffstag
Last Name: Versteeg
Re: Differentials
Post by jeffstag » Fri Oct 08, 2021 4:22 pm
It looks like I can mix and match the different styles of differential halves. I can used the bottom half with the thru bolts, and then go with a top half with or without grooves. Both look good in terms of wear.
23 Touring
23 Fordor
25 TT
27 TT
Re: Differentials
Post by speedytinc » Fri Oct 08, 2021 4:40 pm
I have switched tops. The axle gear hole is/was originally 1.812" Measure them, to know for sure.
A best guess on the stud type usage is 14-20,21. The first gen after the 1.807" axle gears.
