Support Forum
Complete set of Forum Rules  Forum Rules
 MichaelPawelek
- First Name: Michael
- Last Name: Pawelek
						Post
								by MichaelPawelek » Fri Oct 08, 2021 9:51 pm
			I have three Model T’s and when re-building them bought new radiators and took the water pumps off. Here in Texas it gets really hot in the Summer but I never have had a over heating problem. I still see many T’s for sale with water pumps installed.
No bashing or opinions on water pumps please. Just chime in with number of T’s with and without water pumps. I am curious as to the ratio currently.
I’ll start.
3 without water pumps….
 Bill Robinson
- First Name: Bill
- Last Name: Robinson
						Post
								by Bill Robinson » Fri Oct 08, 2021 9:58 pm
			5 T's currently without.
2 previous T's without (my first T had a water pump when I bought it- got my radiator fixed).
The weather gets hot in Alabama, but my T's run cool.
 Novice
- First Name: Jim
- Last Name: Davis
						Post
								by Novice » Fri Oct 08, 2021 10:06 pm
			Three Ts two came with water pumps one stock
						Post
								by Scott_Conger » Fri Oct 08, 2021 10:10 pm
			4 T"s
all came with pumps
all came off
2 stayed off and ran just fine
2 went back on; those cars run cool-ish with, and boil quickly without
have too many demands on my $$ to buy 2 new radiators simply to remove pumps and meet with everyone's approval. I'm too old to give a damn what people think.
Tyranny under the guise of  law is still Tyranny
						Post
								by Mark Gregush » Fri Oct 08, 2021 10:29 pm
			I am with Scott on this, too many people get their knickers in a bind as soon as some post or asks about a water pump. I have and will, if needed, use one.
 Alan Long
- First Name: Alan
- Last Name: Long
						Post
								by Alan Long » Fri Oct 08, 2021 11:00 pm
			I have 3 T’s and no Water Pumps!
This subject will create many opinions but 15 Million of them (less a few) didn’t have them ex factory but, had clean blocks and Radiators!
Alan in Western Australia
 Bill Coyle
- First Name: Bill
- Last Name: Coyle
						Post
								by Bill Coyle » Sat Oct 09, 2021 12:56 am
			I've been running one on my 26 roadster since I finished it 6 years ago.  Clean block and head.. good radiator too.  Checked head temp this summer at 159 deg F after 14 miles with air temp in the upper 80s running 28mph on flat ground.  My 2 friends in WVa run them also.  I would rather error on the safe side.  I wonder why Henry put a water pump on the model A...  Hmmm...
    either way, just enjoy them, Bill
						Post
								by Rich Eagle » Sat Oct 09, 2021 1:43 am
			None of my 6 T's have water pumps. I had a nice one on my Speedster for a year in the '60s but didn't see an improvement. I have no doubt some do help but didn't continue experimenting.
 Duey_C
- First Name: Duane
- Last Name: Cooley
						Post
								by Duey_C » Sat Oct 09, 2021 1:53 am
			Two of my three have (wheel chocks) pumps.
One could probably do without the pump now as he's broke in and happy.
Two, won't get changed. He works too good and paraded with ears up without question. With a Maxwell? fan. Actual air flow.
Three, TT didn't have one and didn't much care.
 dykker5502
- Last Name: Deichmann
						Post
								by dykker5502 » Sat Oct 09, 2021 7:30 am
			3 T's and have never had waterpumps.
One had a tendency to be hot and boil. Radiator fix fixed that. One more have got a completely new radiator but that was more because the old was leaky.
									Ford Model T 1914 Touring
						Post
								by TWrenn » Sat Oct 09, 2021 8:16 am
			ARTHUR!!....where are you?
 FundyTides
- Last Name: Wilson
- * REQUIRED* Type and Year of Model Ts owned: 1927 Canadian Touring
						Post
								by FundyTides » Sat Oct 09, 2021 8:37 am
			27 Touring. Had water pump when we bought the car from original owner. Also had a large damage to the radiator hidden behind the license plate. Would overheat in parade situations. Eventually bought a new rad and removed the leaky pump. No problems since.
 Pat Branigan Wisc
- Last Name: Branigan
- * REQUIRED* Type and Year of Model Ts owned: 1909 two1910,1911, 1913 Tourings
						Post
								by Pat Branigan Wisc » Sat Oct 09, 2021 9:21 am
			Six Ts No pumps No problems. 1909 to 1913.
						Post
								by TXGOAT2 » Sat Oct 09, 2021 9:33 am
			160 F is too cold. 180-200 F is better. If I had a TT truck, I'd probably put a water pump on it, with a 180 F thermostat that had a small bypass hole drilled in it. And yes, you can put oatmeal in your radiator, but why bother? No water pump; runs fine in 100 F weather. (Berg radiator) I do run a fan to prevent overheating when stopped to open gates, etc. I can get by without it if need be.
TXGOAT2 on Sat Oct 09, 2021 9:46 am, edited 1 time in total.
 Charlie B in N.J.
- First Name: CHARLIE
- Last Name: BRANCA
- * REQUIRED* Type and Year of Model Ts owned: "27 Tudor /  "23 Touring
- Board Member Since: 2010
						Post
								by Charlie B in N.J. » Sat Oct 09, 2021 9:35 am
			Had 3 T's. 2 with 1 without. Left them on. The last one, a 23' Touring had one installed by the previous owner who had it installed to cure an overheating problem when he drove in the local Memorial Day Parade once a year. Probably a band aid for a failing radiator.
						Post
								by TXGOAT2 » Sat Oct 09, 2021 9:47 am
			If you run a water pump, keep the seal tight. A leaky seal risks pulling air into the system at road speeds, and you DO NOT want that to happen.
						Post
								by speedytinc » Sat Oct 09, 2021 10:34 am
			3 of 4 removed. #4 rajo has one still. I have removed at least 6 on motor rebuilds/repair jobs. One recent motor job, I couldnt talk the guy off the idea. The motor was beautifully restored. 50 miles later it had melted grease & water puke all down the left side. Still pissed.
 John Codman
- Last Name: Codman
						Post
								by John Codman » Sat Oct 09, 2021 10:38 am
			No pump on my '27. It has a Berg's flat-tube radiator, and here in SW Florida's 90+ degree heat it runs cool and never overheats.
 Les Schubert
- First Name: Les
- Last Name: Schubert
						Post
								by Les Schubert » Sat Oct 09, 2021 10:51 am
			I’m looking for a useable pump as I want to install a heater in my coupe project for cold weather operation. I don’t want to use a manifold heater!
						Post
								by Norman Kling » Sat Oct 09, 2021 11:03 am
			Some important things if you do use a water pump.
1.  Be sure to use waterpump grease in it, not ordinary grease.
2. Be sure to check the fluid level every time before you start the engine.  A small leak can drain the block while parked.
3. Be sure the bushing and packing are in good condition.
4. If you drive in cold weather, use a thermostat to keep the engine up to correct temperature.
5 . Use a motometer or other temperature gauge to see if it is warming up in cold weather.
If you do all these things and fix any problems with it, you will be OK.  But there are already many maintenance things to do and adjustments to make without a pump, so that just adds a few more.
 Harry Lillo
- First Name: Harry
- Last Name: Lillo
- * REQUIRED* Type and Year of Model Ts owned: Speedsters, racers, depot hack, coupe
						Post
								by Harry Lillo » Sat Oct 09, 2021 11:04 am
			I have six Model T's running without water pumps. Three of those have no fans either.
My Roof Type C 16 valve board track racer has a water pump and dash temperature guage.
It stays in the normal range at any outdoor temperature here in Alberta.
Thank you for starting this thread to get an unbiased opinion on water pumps.
An old friend had difficulties keeping his speedster running in the normal range. He installed one of those little top radiator neck water pumps.  It dropped his temperature about 15 degrees F.
Harry
 John Dow
- Last Name: Dow
						Post
								by John Dow » Sat Oct 09, 2021 11:06 am
			I don't have one on my '23 Touring.  While moving even on the hottest (95+ degree) summer days you don't need one if your radiator is good.
 Been Here Before
- First Name: George John
- Last Name: Drobnock
						Post
								by Been Here Before » Sat Oct 09, 2021 11:22 am
			Say what you want. The Family T , rebuilt over 50 years ago has a water pump. And there never has been an issue. Living in central Pennsylvania where  travel is best on the level, but hilly valley roads,  the water pump comes into its own when crossing one of the local "mountains" to drop into into a neighbouring valley. Along the way to the top of the mountain, one would come across a pipe from a mountain spring to refill the radiator or water a horse.
Over all,  even with a clean and factory established thermo-cooling system, new radiator, the water pump is not an evil accessory  or crutch.
Lets face it, Henry wanted to save money where he could. A water pump was just an other expense for his company. If he wanted to really eliminate liquid cooling he would have built a car similar to the Franklin.
 RustyFords
- First Name: Don
- Last Name: Allen
						Post
								by RustyFords » Sat Oct 09, 2021 1:46 pm
			'24 Touring....new Berg's radiator...no water pump.
I've run it in 100+ weather here north of Houston...never even thinks about overheating.
									1924 Touring
 troutjohn
- Last Name: Trout
- * REQUIRED* Type and Year of Model Ts owned: 1923 runabout, 1913 touring
						Post
								by troutjohn » Sat Oct 09, 2021 2:07 pm
			Two Ts 1912 and 1913. Both run nice and cool with water pumps.
John
						Post
								by John kuehn » Sat Oct 09, 2021 2:21 pm
			I have flat tube radiators on my 3 T’s and saved my water pump money.   They cool OK and it’s one less part to deal with.
 tgarron33
- First Name: Thomas
- Last Name: Garron
						Post
								by tgarron33 » Sat Oct 09, 2021 2:39 pm
			1 T, 1922, with.  Because it had one when we inherited it.
- Last Name: House
						Post
								by George House » Sat Oct 09, 2021 2:47 pm
			None of those boat anchors on my 7 T s....
						Post
								by DanTreace » Sat Oct 09, 2021 3:01 pm
			Have owned over 15 T’s, current stable contains 4.
Never a water pump.
									The best way is always the simplest. The attics of the world are cluttered up with complicated failures.     Henry Ford
Don’t find fault, find a remedy; anybody can complain.   Henry Ford
 Tim Williams
- Last Name: Williams
- * REQUIRED* Type and Year of Model Ts owned: 1925 Model T Speedster, 1922 Model t Speedster project
						Post
								by Tim Williams » Sat Oct 09, 2021 6:39 pm
			I use to use one until I got a new radiator 10 years ago and haven't since.
Tim
- Last Name: Juhl
						Post
								by Oldav8tor » Sat Oct 09, 2021 8:00 pm
			My '17 came with an original radiator and water pump.  The pump was frozen and the radiator had a cracked neck.  I chose to install a flat-tube Bergs and no pump.  I've never come close to overheating, even driving slow on 90° days.
						Post
								by TRDxB2 » Sat Oct 09, 2021 8:03 pm
			Sold it on eBay
 and got a Berg Radiator
TRDxB2 on Sun Oct 10, 2021 4:51 pm, edited 1 time in total.
 Art M
- First Name: Art
- Last Name: Mirtes
						Post
								by Art M » Sat Oct 09, 2021 10:54 pm
			Tim, I finally got on this site.
I am with Bill Coyle on this one.  My 23 touring came to me with a waterpump 44 years ago and it is still on the car.
My round tube  radiator is original to the car.  Without the  pump the car runs cool, but I continue to use it because I feel it helps prolong the life of the radiator.
There are variations in the design and performance of the various brands of waterpumps, so expect different results.
My advice is to add a pump while the radiator is still good to help prolong its life.   Henry deleted the pump in order to pump up his profit or to reduce the price of the car. Remember, most of these cars lasted a short time.  Radiator life was not a concern.
Art Mirtes
 Kevin Pharis
- Last Name: Pharis
						Post
								by Kevin Pharis » Sat Oct 09, 2021 10:58 pm
			My speedster was running hot in the rear cylinders at high speed (55+) causing 3&4 pistons to skuff... I really enjoy my thermostatically controlled electric water pump now
 Mark Osterman
- Last Name: Osterman
						Post
								by Mark Osterman » Sat Oct 09, 2021 11:09 pm
			I’ve owned two model Ts. My first car had an old honeycomb radiator and needed a water pump to prevent overheating. Sold that one after thirty years. My current car has a new Bergs radiator and I’ve never used a water pump on this one. It’s driven around 100 miles a week.
 Colin Mavins
- First Name: Colin
- Last Name: Mavins
						Post
								by Colin Mavins » Sun Oct 10, 2021 8:47 am
			My 1912 Had one on since 1960  In 2013 when I broke the crank we tried it with out ,the engine temp went down and does not boil anymore . My rad is the original round tube and has one tube blocked off. The water pump is now a wall hanger.
						Post
								by TXGOAT2 » Sun Oct 10, 2021 9:50 am
			A water pump could be a practical accessory for a car in taxi service or delivery service in  city traffic  or for a TT truck most anywhere. A water pump could be advantageous in mountain country or hot desert country. They require proper installation and proper maintenence to be effective. I believe that a thermostat with some bypass capability would be needed in most situations. Most applications that would benefit from a water pump would also benefit from a fan. Any Model T needs a clean cooling system and a radiator in good condition. Modern anti freeze offers several advantages when used in the Model T system, with or without a water pump and/or a fan.
TXGOAT2 on Sun Oct 10, 2021 1:24 pm, edited 1 time in total.
 RGould1910
- Last Name: Gould
						Post
								by RGould1910 » Sun Oct 10, 2021 10:05 am
			Two Ts with Climax water pumps, none without.
 Luke
- First Name: Luke
- Last Name: P
						Post
								by Luke » Sun Oct 10, 2021 4:39 pm
			Do you guys not realise that the Pump Police are compiling a register from this thread and will come visiting shortly!
Mind has one, it came with it, it's a neat period addition and I'm happy with it. If it didn't have one I probably wouldn't go looking - unless there was an issue, in which case I'm with Scott, a pump is probably cheaper than a new radiator, especially here.
						Post
								by TXGOAT2 » Sun Oct 10, 2021 5:36 pm
			If your radiator is badly clogged, your water pump may pump your water out the overflow tube at road speeds. A badly clogged radiator will cause excessive pressure drop in the system, which will aggravate any tendency for the pump to suck in air at the shaft seal, which will cause steam pockets and aggravate corrosion and overheating. Pump or no pump, you need a clean cooling system.
 MbStew5755!
- Last Name: Stewart
- * REQUIRED* Type and Year of Model Ts owned: 1926 Model TT Ford Truck
						Post
								by MbStew5755! » Mon Oct 11, 2021 3:49 pm
			I have a 1926 TT Truck and removed the water pump when I bought it and it runs fine.
						Post
								by Steve Jelf » Mon Oct 11, 2021 5:51 pm
			I have two T's that I don't consider "projects". They both run but are sometimes grounded for repairs not related to cooling. Neither has cooling troubles in the normal course of things. Neither has ever had a water pump that I know of. Both had radiators that no longer radiated. A recore cured the 1915 and a new Berg's did the same for the 1923.
 varmint
- First Name: Vernon
- Last Name: Worley
						Post
								by varmint » Mon Oct 11, 2021 6:04 pm
			I'm afraid to use a water pump on our T.  After applying the soap, the water pump might take off some of the paint along with the dirt.
Vern (Vieux Carre)
						Post
								by TXGOAT2 » Mon Oct 11, 2021 6:17 pm
			The decision on whether or not to add a water pump ought to be based on conditions under which the vehicle is operated,  not the condition of the cooling system.
 TBones12
- Last Name: Poane
- * REQUIRED* Type and Year of Model Ts owned: 1916  Hack, 1910 Touring, 1914 Touring, currently a Touring 1912, 1912 Torpedo Roadster
						Post
								by TBones12 » Mon Oct 11, 2021 9:49 pm
			2 T's....no pumps, but I have one in a box.
Took it off because it leaked!
