Simmons / Duplex Carburetor
Mark Osterman
Last Name: Osterman
Post by Mark Osterman » Tue Oct 12, 2021 8:32 am
Found this Duplex “straight through” carburetor at Hershey and it needs new valve discs. The parts are the same as the NH carburetors. Seems that they don’t have a wire retaining clip or screws. So is the disc a friction fit?
Re: Simmons / Duplex Carburetor
Post by speedytinc » Tue Oct 12, 2021 8:39 am
Seems to me, they used a single screw in the middle of the shaft. This choke shaft could have been changed also. Late T butterfly with the 3 tabs will work.
Mark Osterman
Last Name: Osterman
Post by Mark Osterman » Tue Oct 12, 2021 9:28 am
There are no holes in the shafts. I can switch out the shafts with new NH shafts.
FATMAN
First Name: ROBERT
Last Name: BERGSTADT
Post by FATMAN » Tue Oct 12, 2021 9:33 am
Use the 3 tab butterfly, Bob
Post by Scott_Conger » Tue Oct 12, 2021 9:55 am
Mark
save and clean the jet and save and clean/sharpen the needle. They are most definitely not the same as NH parts. The float valve is the same though.
Corey Walker
First Name: Corey
Last Name: Walker
Post by Corey Walker » Tue Oct 12, 2021 11:45 am
Those came with a dimple in the center of the butterfly that made a friction fit. Al see o if you want to use the butterfly with the staple you can just drill 2 holes in the shaft you have there.
Post by Scott_Conger » Thu Dec 01, 2022 9:50 am
originally, both the throttle and the choke only had one screw holding them in...
Don't lose that screw!! It is a very unusual thread. I can make them, but they are expensive.
