Chicago Transmission
Topic author - Posts: 56
- Last Name: Greger
I have a Chicago Mark-E transmission and would like to know if anyone would have the modern numbers for the tapered roller bearings in it. They are Bock bearings and no one seems to be able to ID them. Thank You for any help. Dan
- First Name: Michael
- Last Name: Peternell
- * REQUIRED* Type and Year of Model Ts owned: TT gas truck, T tractor conversions, '15 touring, '17 speedster, '26 16 valve speedster
Re: Chicago Transmission
Does your case say patent pending? I had a couple I was messing with and the patent pending bearings were made of unubtainium.
Mr Morsher may have some answers for you.
- First Name: DAN
- Last Name: MCEACHERN
Are you sure it has tapered bearings in it? Most of these use ball bearings, at least in the ones I have. Opps- on edit, mine have tapered roller bearings as well.
If you have accurate ID, OD and width dimensions, its pretty easy to find the Timken equivalents. Post the info here and I'll look them up.
Last edited by Dan McEachern on Thu Oct 14, 2021 12:39 am, edited 1 time in total.
I've heard of bock beer, but bock bearings?
Took me a while, wanted to default to pillow bearings;
https://www.google.com/search?q=%22Bock ... nt=gws-wiz
- Last Name: Morsher
From my poor memory , the early ones are made a bit different in many areas. I don’t remember exactly but don’t think they will interchange and have the chunky looking tapered roller bearings in them. I only went through a couple of the later ones, which were nice, and the timkens were in great shape. Great transmissions, but I’d look for a later one, like Mike mentioned .
They looked like this. I’d take Dan up on the offer. It used to be easy, every little town around these parts had a bearing supply store with knowledgeable counter men. No more.
- Last Name: Greger
Thank You all for your reply's. What I have is 2 transmissions, both have the Bock tapered roller bearings in them. They are different as one is made fore 2 u joints (front and rear) and the other just uses a rear joint and has a square shaft in the front that goes directly in to the Ford trans. What I was missing is some the outer cups, one for the large input shaft bearing and two for the lower cluster gear shaft. I found a bearing supply house that interchanged the cup numbers to current Timken numbers and ordered them (the price was Not Cheap but they can get them). I still have to make two of the threaded retainers that hold the cups in.
Since these are bolted directly to the back of the Ford trans. do I need a frame mounted bracket to help support it? One is going to go in a TT and the other in a roadster.
Once the trans. are done then the fun begins cutting the drive shafts and tubes to make them fit, any ideas on doing this would be appreciated. Thank again ---Dan Greger
The bearings shown in Tim's picture are what was used by Dodge, my 1920 has those on the spindles and full floating rear end.
Support for rear of transmission; I would look into at least adding some type of floating support. That still is a lot of weight hanging off the 4 little 3/8" bolts. Do a search of "mtfca transmission support", you should be able to find a number of ideas.
Mark, it’s been a year or two, but I don’t remember any ball bearings in the Chicago trans, and I had both versions here all apart. Could have forgot, I guess. Dan, I have an original trans support strap here. Drop me an email tmorsher@icloud.com and I’ll send a picture. T
Sorry I will fix that, I was talking about the Dodge transmission.Dropacent wrote: ↑Wed Oct 13, 2021 12:30 pmMark, it’s been a year or two, but I don’t remember any ball bearings in the Chicago trans, and I had both versions here all apart. Could have forgot, I guess. Dan, I have an original trans support strap here. Drop me an email tmorsher@icloud.com and I’ll send a picture. T
- First Name: DAN
I looked thru my notes and bearing drawer and all I have a record of is the front input shaft cup is a Timken #3120. The mating cone is a Timken #3196.
Hope this helps.
Hope this helps.
- First Name: Andrew
- Last Name: Webb
- * REQUIRED* Type and Year of Model Ts owned: 1915 Towncar 1921 Centerdoor 1913 Racer 1927 Fordor 1927 Tudor 1926 Tudor 1927 Coupe 1926 Ute1926 Tourer 1915 Town Car
This worked for me but some you will need to find a metric equivalent
- Last Name: Greger
Thank You Dan and Tracer, I will cross those numbers to metric. Tim, I sent you an email about the transmission strap.---Dan
- First Name: Tony
- Last Name: Bowker
I use a KC Warford in my 1914 Touring and I use the support listed in Lang’s catalog. It’s a little expensive and I’m sure I could make something similar but I needed it in a hurry. While there is no requirement to provide support at the end of the Warford, I was concerned that the mass hanging at the back of the tranny was just too much. No sums, just instincts.
Tony Bowker
La Mesa, California
La Mesa, California
