Rod nut spines but won’t come off
Unprr
Last Name: Schmidt
* REQUIRED* Type and Year of Model Ts owned: 1927 coupe, 1924 Model T pickup
Post by Unprr » Sat Oct 16, 2021 3:32 pm
I’m in help of a little help. I’m checking the shims on my 27 Model T and was replacing the cap and oil dipper, when one of the nuts stated to just spin on the bolt. It will not go on or come off.?
The bolt is not turning.
Has anyone experienced this problem and if so, how do I remove it.
George
Re: Rod nut spines but won’t come off
Post by Norman Kling » Sat Oct 16, 2021 4:07 pm
Try turning the crankshaft so the rod faces straight down. Then put a small punch smaller than the bolt between a jack and the center of the bolt. Then put a little pressure on the jack and use an open end wrench to back off the nut. After you get it off, use a different bolt and nut.
Last Name: House
Post by George House » Sat Oct 16, 2021 4:09 pm
Get another rod bolt and castellated nut. Should be plenty of extras in your club or contact me and I’ll send you a set.
Post by John kuehn » Sat Oct 16, 2021 5:10 pm
Use a pair of vise grips to grip the nut and slowly get it turn as you pull it down. Usually this will work for any stripped nut.
Unprr
Last Name: Schmidt
Post by Unprr » Sun Oct 17, 2021 10:17 am
I will be under my car tomorrow. I will try the first option, since I tried the vise gripes.
I should have another bolt, in my treasure of parts. LOL.
Thanks for the help.
George
Last Name: Strange
Post by CudaMan » Sun Oct 17, 2021 6:55 pm
Since you'll be replacing the rod bolt and nut anyway, why not use a nut splitter to remove the nut?
