Any trick to getting this off?
Topic author - Posts: 1158
- First Name: Robert
- Last Name: Govoni
So I'm trying to fit some wood in place and I see that I have to take off the big nut and top Iron support stud.
This is the nut.
Is there a way to hold this stud without having to use vice grips? I don't want to chew it all up.
This is the nut.
Re: Any trick to getting this off?
Double nut it, perhaps with thin jam nuts, and that will act as a head on a bolt and things can be taken apart
- First Name: CHARLIE
- Last Name: BRANCA
- Board Member Since: 2010
Remove the cap then do a double nut on the threads. Give you something to hang on to.
- Last Name: Govoni
OK now I feel dumb. Thanks!!!!!!
If it was painted in place, suggest scoring the pant around where it meets the body so does not pull or chip the surrounding paint.
or simply saw a clearance slot into the back and slid it over/past the nut. No one will see it and it will still function fine as a tack strip
- Last Name: Govoni
Well that worked. I used two nuts and it came right out. Then I showed my daughter that mechanical trickery.
- Last Name: Tannehill
It’s amazing all the trickerization you can learn here. Ha
- Last Name: Govoni
I've been passing on all your tricks to my 16 year old.
