nh straight through
Topic author - Posts: 381
- First Name: Don
- Last Name: Ellis
nh straight through
How do you tell the difference between a sway back and a straight thru carb float? I saw something about a difference, I want to make sure mines correct.
- Last Name: van Ekeren
Re: nh straight through
Same float for both.
- Last Name: Jablonski
Don;... I've used the same NH float in straight through and humpback casting carbs with no problem
- First Name: Don
- Last Name: Ellis
I know i have too but I ran across a part Langs sells for the straight thru float, a hinge. I wasn't aware of a difference. Part number 6201NHS, kinda pricey too.
