I apologize for the sideways pictures and have no idea why they turn 90 degrees from the image site to here.
Agree with your assessment. Band & lining look like current RM modified, possibly with other period parts additionally modified. manufactured, modified & installed by humble hands of home.MichaelPawelek wrote: ↑Mon Nov 01, 2021 7:30 amI will take some closer pictures today but from looking at current ads for both brands these are not similar at all and have many different parts.
The beauty & reason for the original RM brakes working so well in both directions is that center of band anchor.Mark Gregush wrote: ↑Mon Nov 01, 2021 12:42 pmSomeone welded on that bracket to the backing plate casting and added a pin to the center of the band, something I have thought of. The lever is simply turned around, as are the brake bands. That added pin to the top, which is missing from the RM setup, could be part of the reason why they don't work in reverse as they should. I have given thought on how to add the anchor pin. That setup look like a way to do it.
I know, thats the problem. Earlier, branded "Rockey Mountain" brakes did. Restored a set. Worked great. There is a traceable parentage back to these from the current version. The name Jack Sunderman comes to mind as a reproducer. Memory fades. Weather period original or old repops, they show up occasionally & are worth more than a new set, especially to function.Mark Gregush wrote: ↑Mon Nov 01, 2021 2:16 pmThe current brakes being called RM are copies of the AC brakes that came out in about 1926. They did not have the center anchor. The slotted plates that are attached to the band was their (AC) idea to substitute for the center anchor.
If you keep the transmission brake properly adjusted, you will have brakes in reverse with the new ones. Can be & should be & maintained this way.Mark Gregush wrote: ↑Mon Nov 01, 2021 2:51 pmI had a set of the 1926/27 so called RM's, some of the earlier reproduction ACs (not orginal). I don't know how I screwed up the installation, because they seemed to work good both ways.![]()
I have given thought it was the type of lining that was on them that helped. Another set, on a 1925, with the light colored lining, are absolute sh## for holding in reverse.
